  • SN95 4.6L Mustang Tech
MAF!!!
  • Thread starter Thread starter The Stang GT
  • Start date Start date Feb 2, 2006
The Stang GT
81
  • Feb 2, 2006
Hey guys, I would like to know, what exactly is the purpose of installing a larger Mass Air Meter?????, and what gains can come of it??
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Feb 2, 2006
  • Feb 2, 2006
if it's on a nearly stock stang with a few bolt on's then you really dont need a larger MAF cause you wont gain performance if anything you can loose HP, but if its S/C'd then you could get a bigger one and have it calibrated to your injector sizes and all that neat stuff....
ProCharger GT
153
Cleveland
Feb 2, 2006
  • Feb 2, 2006
dont do it unless your modified
J
jimfitzgerald
6,672
  • Feb 2, 2006
The MAF is a sensor that measures the amount of oxygen entering the intake. The computer uses this information to send the correct amount of fuel to maintain the air/fuel mixture. If you significantly increase the amount of air entering your engine, such as with a supercharger, you will need a larger MAF to handle the increased airflow. Otherwise, just keep the MAF you have.
imblown-ru
247
Roanoke VA
Feb 2, 2006
  • Feb 2, 2006
your maf sensor translates the airflow into a certain number of volts which it turns into a number. the max a stock maf can read is like 4 volts or 5 volts, and the highest number it can read is around 1200. My car has the paxton on it and at 4800rpm my maf is around 990 which means it is very close to pegging out. i couldnt run my car any higher because it was dangerously lean, but you can see that it was well on its way to pegging. So really if you are less modified than me, you dont need a new one.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
