MAF
  • Thread starter Thread starter bi19tri
  • Start date Start date Aug 23, 2006
bi19tri
45
  • Aug 23, 2006
How do you test you maf?
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Aug 23, 2006
  • Aug 23, 2006
Pull the engine codes and it'll tell you... go to Autozone or Advance and they'll do it for FREE
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 23, 2006
  • Aug 23, 2006
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR [[
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Wal-Mart may now have the LCD display scanner for less than $35
JChalfan
551
Bellevue, WA
Aug 24, 2006
  • Aug 24, 2006
Why do you think there's something wrong with it?
Jeff
bi19tri
45
  • Aug 24, 2006
No I was just wondering if it can be tested with a multimeter!
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Aug 24, 2006
  • Aug 24, 2006
I dunno
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 24, 2006
  • Aug 24, 2006
Code 66 MAF below minimum test voltage.
Insufficient or no voltage from MAF. Dirty MAF element, bad MAF, bad MAF wiring, missing power to MAF. Check for missing +12 volts on this circuit. Check the two links for a wiring diagram to help you find the red wire for computer power relay switched +12 volts. Check for 12 volts between the red and black wires on the MAF heater (usually pins A & B). while the connector is plugged into the MAF. This may require the use of a couple of safety pins to probe the MAF connector from the back side of it.
There are three parts in a MAF: the heater, the sensor element and the amplifier. The heater heats the MAF sensor element causing the resistance to increase. The amplifier buffers the MAF output signal and has a resistor that is laser trimmed to provide an output range compatible with the computer's load tables.
The MAF element is secured by 2 screws & has 1 wiring connector. To clean the element, remove it from the MAF housing and spray it down with electronic parts cleaner or non-inflammable brake parts cleaner (same stuff in a bigger can and cheaper too).
The MAF output varies with RPM which causes the airflow to increase or decease. The increase of air across the MAF sensor element causes it to cool, allowing more voltage to pass and telling the computer to increase the fuel flow. A decrease in airflow causes the MAF sensor element to get warmer, decreasing the voltage and reducing the fuel flow. Measure the MAF output at pins C & D on the MAF connector (dark blue/orange and tan/light blue) or at pins 50 & 9 on the computer.
At idle = approximately .6 volt
20 MPH = approximately 1.10 volt
40 MPH = approximately 1.70 volt
60 MPH = approximately 2.10 volt
Check the resistance of the MAF signal wiring. Pin D on the MAF and pin 50 on the computer (dark blue/orange wire) should be less than 2 ohms. Pin C on the MAF and pin 9 on the computer (tan/light blue wire) should be less than 2 ohms.
There should be a minimum of 10K ohms between either pin C or D on the MAF and ground.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
RoadKill96
39
Victorville CA
Aug 26, 2006
  • Aug 26, 2006
ok here's one for you's guys when i press on the gas pedal and my check engine light comes on when i take my foot off it it goes off i have no clue what the .... is going on thanks for all of your help
Pete AKA RoadKill96.
oh my mustang is a 1990 with a 5.0 HO and AOD trans
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 26, 2006
  • Aug 26, 2006
Like I said earlier -dump the codes.
RoadKill96
39
Victorville CA
Sep 25, 2006
#10
  • Sep 25, 2006
  • #10
finally found out what it was my darn Air charger temp sensor went out
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
Electrical Help me find a missing connection
  • Xavierg208
  • Feb 15, 2026
Fox 5.0 Mustang Tech Feb 17, 2026
Mcmahst
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
