Magnaflow tips issue
CrazyHorn
184
Gatineau
Well the same thing hapenned again, the tips got loose, or well its the rod that goes to the rubber insert in the back bumper thats loose, I know its the bolt that holds it that just keep getting loose so what would you guys do in my situation, would you get it welded ? Anyways help is apreciated as its a pain in the ass to go and tight that bolt.
I just got magnaflow tips welded on.. it cost 30 bucks, because they had to bend an extra little piece of pipe for the drivers side. But yeah.. 30 bucks to never have to think about it again seems a good deal to me.
Ok, I'll try loctite before the welding, I did tight them as hard as I could the last time and it was still loose today but the rod was a little further than it should have been the last time I tight it.
With the loctite if I put that on the bolt, do I need to remove the bolt completely ?
I used loctite on mine and am glad i did, after i installed my x pipe, one of my tips stuck out like 2 inches farther, i dont know if it was a bad fitting pipe or what but it pushed the whole side of the catback out the back of the car and if i had them welded my tips would be ruined because they would have had to cut them and re weld. I used loctite and just had to break the allen screw loose and adjust and re loctite.
Good point. Mine needed adjusting when I got the mid pipe too. It'd suck if you welded them!
