Has anyone put magnum 500's on a 65? If so did you have fitment issues? I put a 15x7 on the front and it hits the upper control arm. Has anyone else had problems? Also will the mags fit with the granada swap?
The originals won't due to the smaller center hub but the later 14's ones will since they were an option on the Granada. Supposedly aftermarket Magnums use the larger center hub too.
I had the stang on jack stands. When i turn the wheel to the left, the rim hits the uca. I have the 15x7's so i think i will be fine with the granada swap. I believe i have the larger center hub.
