In this thread, I am not concerned about built short block options, or what blower I should use, or if I should use a turbo setup instead of a blower. I am asking about the rear-end, and exactly how to keep it from dying when running forced induction and some drag slicks at the track.
With that out of the way, lets get to it. Quite some time ago, I posted a thread asking about what is needed to "harden" the rear-end of my '00 GT for serious drag racing with up to 600HP at the wheels. Well, I know now that I am going to shoot for a more modest 450 - 500 at the wheels with race fuel, and a good bit less for daily driving on pump gas.
So, I have recently taken the info in that old thread and used it to come up with a Bill of Materials for this upgrade. It turns out the price total is much less than I was expecting. Maybe I have made some mistakes, or cheaped out, let me know. Also, based on my conversations with some local Mustang guys, I have discovered that I can add a Cobra rear brake upgrade at the same time for very little extra cost.
I am not sure exactly when I will get to this, but I am expecting it to be around Summer-Fall of '07, based on the cost I have come up with. If the cost is actually much higher, I will need to move it out further. Since I have some time between now and then, I was hoping to get specific feedback for my current plan of attack. Below is a list of what I am looking at, at the moment. It comes from various online sources.
Item / Mfg / Part # / Cost
31-spline axles and bearings / Alloy USA / 12187 / $209.95
3.73 ratio gears / FRPP / m-4209-f373n / $165.95
Cobra rear brake bracket and rotor kit / FRPP / m-2300-m / $174.88
Diff girdle / FRPP / m-4033-g1 / $177.95
Friction modifier / FRPP / m-19546-a1 / $3.50
Gear install kit / FRPP / m-4210-b / $79.88
Cap studs for diff and girdle / FRPP / m-4034-a / $35.00
31-spline limited slip diff ('03 Cobra OEM) / FRPP / m-4204-f318c / $258.95
Speed cal / FRPP / m-9731-t99 / $89.00
Total: $1195.06
So, I found the Alloy USA axles included the axle bearings and were still a good bit cheaper. If I do not get the axle bearings that way, I need to add the extra cost for the right install kit, too (~$110, vs ~$80).
I also found the limited slip 31-spline diff that was the OEM diff for the '03-'04 Cobras (the one with the carbon fiber clutch plates) for less than $260. That seems like an excellent option to me. Anyone think this one would not handle the occasional track use with slicks? I am not overly excited about a locking diff. I am hoping an LSD model would be good enough for me, I certainly think it is more streetable (IIRC).
Anyone see any of the "little things" I may have missed? I think the install kit is complete enough, and I included the friction modifier in the list. I do not need to get any of the diff fluid, that is why I didn't include it here.
Any specific thoughts/ideas/suggestions?
Thanks in advance, everyone!
:SNSign:
Total: $1195.06
:SNSign:
