Making my first runs with DRs tonight, any advice?
I'm heading to IRP tonight after work for Test & Tune. Typically its a little slick on Tuesdays because of the retarded "ricers". I'm not generalizing about all import owners, but the "hey I'm going to drive my 18-second Civic DX through the water box and carry water to the starting line"-type drivers.
My plan was:
- Nice 8-10sec burnout
- Launch 3500RPM
- Slip the clutch off the line
- Hold on for dear life
BTW, the car has 3.73s and the only suspension work is H&R springs and Mach I shocks which probably aren't helping much. I also still have the stock axles which I would like to nurse along until this winter until I can get the cash to replace them, hence slipping the clutch. So no 5k drops off the line quite yet.
Any suggestions on tire pressure or anything else are welcome!
Thanks
I would do a longer burnout, in MM&FF about 2 years ago they did a good write up on burnout techniques. They said to really do a good burnout with DR because the compound just gets stickier and stickier, I would do a good 25 second burnout
that is way too long of a burnout. when you do a burnout like that the rubber compund goes from getting sticky to gooey. when it gets gooey it actually hooks mush worse. a good 8 - 10 second burnout does just fine with drag radials :nice:
Well, I guess I'm just going to have to wait in suspense at what my times could be. For some reason just as I was leaving work, I got on irponline.com and looked at the schedule and they aren't running this Tuesday :mad:
Oh, well. Good things come to those who wait :D
:stupid:
A 25 second burnout on DR's will start to literally shred rubber off the tire. :nonono:
