Mak's AOD to T-5 conversion. Progress/?'s
  • Thread starter Thread starter Makdaddymac
  • Start date Start date Feb 28, 2008
M
Makdaddymac
323
orlando
Feb 28, 2008
  • Feb 28, 2008
hello got my official aod to t-5 thread going! with questions
1)got the speedo cable rerouted, damn..anyways i was going to hook the gauge back up but im waiting to change some bulbs...anyways I had to take the bracket that holds the cable to the frame in order to get slack to run it up to where it could connect to the speedo. but i noticed the cable is right on the steering shaft that bolts to the column. and if i run it under that thing it will be close to the headers? what should be done here?
2)got the manual pedal assmbly up by one nut!!! but i stopped cause im having problems trying to get it in there so where i can press the pedal(s) without it hitting the wiring harness';and that brake light thing wont reach like it use too
also there is a little black thing with a red and black wire running into it and seems to have a spring mechanism that i think goes on the pedal rod(with the pin too hold it on) but i have no idea wtf is does or how to put it on correctly, i can figure out how the little brake light thing works i swapped the bracket thing that holds the piece over to the my manual pedal assembly cause it didn't have one; i can figure out that much, as soon as i get some slack, but the other thing with the wiring and spring ??!!!
3)now what should i know about starting the car while not in park, i know the car wont start unless in P or nuetral or something along those lines wiht the AOD. is this going to effect me or what??
4) clutch cable installation!!, i was planning on just insatlling the manual pedals and driving the car with the aod till i have time and space to put the t-5 in, no harm right! but if i put everything back together i dont think i can get a clutch cable down there!!!!!!!!!!!!! should i run my cable through and put it on the quadrant to save me work effort, or what? i also need to install my firewall adjuster! so should i just pop that on there and run the cable to the quadrant and just have it zip tied in a safe place temporarily or is it no big deal to run it to the quadrant later.....i have asked others that said it possible, but im not seeing it!
4.5) how does the adjuster go on the cable
please excuse the my constant use of thing or piece, i really have no idea what some of this stuff is. not to mention really what im doing...lol...im really learning and i havnt broke nothing!
5.0 Nostalgia
904
CT
Feb 28, 2008
  • Feb 28, 2008
4. I don't see why you can't install the cable when you put the transmission in. It takes longer to jack the car up than install the cable. You just slide the quadrant end through the firewall, then go in the car, grab it, and connect to the quadrant. You do this before attaching the other end to the clutch fork.
4.5. You have to pull the rubber piece off the white plastic piece on the cable, shim the prongs off, then slide the quadrant on where the rubber piece was before you pulled it off.
cenok is family
1,409
69
79
Norman, Ok
Feb 28, 2008
  • Feb 28, 2008
the switch you are referring to sounds like the neutral safety switch.
M
Makdaddymac
323
orlando
Feb 28, 2008
  • Feb 28, 2008
i dont think its the nuetral safety! but i couold be wrong, also im talking about another thing that was hooked up on the aod pedal it something to do with brake!?
anywyas i got a pic to help clear two things up
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
314
281
134
Apache Junction, AZ
Feb 28, 2008
  • Feb 28, 2008
Don't forget that at some point you're going to have to address the reverse light switch, otherwise you're going to have your reverse lights on all of the time (or never on at all).
The speedo cable is a bastard to deal with on Foxes, no matter how you're doing it. The fact that you've got the dash halfway torn apart should, if anything, make things EASIER because you don't have all of that extra crap in the way. The easiest way I've found to reconnect the speedo cable is to still have the gauge cluster loose so you can move it around a little bit to help the cable mate up to it. Also, because you're trying to fit a square peg into a square hole with the cable, itself, going into the back of the gauge cluster, sometimes things don't always line up on their own. I've always had to leave the tranny end of the cable loose so I can turn the cable just a smidge (helps to have a partner do this for you) while you're simultaneously trying to poke that sucker into the back of the gauge cluster.
FWIW, every time I've buggered with the speedo cable on a Fox, the thing always looks like (from the underside looking up) the cable is jammed in there diagonally as it comes out of the back of the cluster, as it has to make a sort of zig-zag to clear the dash/steering column frame on its way to the firewall hole. Crappy design, would've been better if they'd have been able to put the hole a few inches over so the cable sheath didn't have to make such a sharp bend (which might explain half the reason, beyond the plastic VSS gear, why speedos on these cars always wind up bouncing and making weird nosies).
M
Makdaddymac
323
orlando
Feb 29, 2008
  • Feb 29, 2008
im still confused as of what is left to do near the pedal assembly, i was told i dont have to have to connect the nuetral safety switch. but there is issues with KOER or KOEO running code test or w/e., what is the run down on this. I don't want to mess up something when i plug my diagnostic reader in... and i dont want to really connect it if it isn't needed! especially since i got the maual pedals all mounted in and just need to figure out the brake light pice that goes on the rod!
and also i also have no idea wtf to do to make my reverse lights to work! i would like my reverse lights to work, and i have the t-5 connector in my swap parts pile, but im reading that i have to splice it in? do i connect it to the trans and splice it to the aold auto part???/ or what..
Darkwriter77
5 Year Member
Jul 1, 2005
314
281
134
Apache Junction, AZ
Feb 29, 2008
  • Feb 29, 2008
The reverse light switch is down by the tranny. I'm not 100% sure, but I think you can just splice into the wiring for the reverse lights from where the AOD plugged in, unless it uses the same kind of plug (in which case you can just poke it right in there).
It's hard for me to elaborate much more on that because whoever did the AOD-to-T5 swap on the notch that I had did such a damned good job that I never knew it was originally an AOD until I checked the door option codes (and a hole was never drilled in the firewall for the hold-down screw of the clutch cable grommet). Everything under there looked 100% stock, with no spliced connections to be found. I don't know if Frankenstang's '80 Capri was originally an auto or if it was always a manual, as some things similarly weren't quite 100% kosher when I went to deal with the clutch cable on it, but we did find out that if the wiring of the reverse light switch is damaged or disconnected (hers had burned through from laying against the exhaust), it will cause the reverse lights to stay on full-time when the ignition's on.
The reverse switch is a pretty simple two-wire deal, really. One wire in, one wire out, as I remember it ... or it may just be a single-pole deal. (Sorry, my memory is utter poop. ) If there's still a plug with wiring there on the reverse switch sticking out of the side of the T-5, you should be able to just splice right into that, crimp-connect and/or solder and then wrap your connections, and be good to go; if it's just the switch, itself, sticking out of there, you'll have to visit your local auto parts or Radio Shack store for some generic connectors (either spade or "bullet" connectors, whatever applies to your tranny's switch terminal(s)).
Just play with it a bit and you'll figure it out pretty easily. It's not like you're going to fry anything if you get those two wires confused - it'll just make the lights come on, so then you know to just reverse the two wires (or make sure you've got a good connection).
EDIT: Indeed, the neutral/clutch safety switch is optional for the T-5 swap. I'd wire it in there just to be on the safe side. While you're at it, you can go a step further and wire in an anti-theft kill switch in-line with your clutch safety switch. The way it works is that when the clutch pedal is pushed in, the switch completes the circuit and allows the starter to crank; if the pedal is up, the switch breaks the circuit and prevents cranking. If you wire a switch in-line with that and hide it someplace like under the dash or seat, in the ashtray, or elsewhere, you can add a bit of theftproofing for just a couple of bucks. It doesn't have to be a fancy or high-amp switch, either, because there's not much current going through - it's just a signal wire, much like the amp on/off wire on a stereo system.
M
Makdaddymac
323
orlando
Feb 29, 2008
  • Feb 29, 2008
thanks darkwriter, i think im going to pass on the nuetral safety. i have the 5speed habit of pressing the clutch in to start my all my DD, and it will never go anywhere, plus no one will ever drive my 5.0 unless they really know how to drive manual!!!!!!
i just needed to make sure the car was going to start once its all together
i cant wait to get everything toghther and drive the aod with the manual pedals, that alone means im close to the fealing of slapping gears......i feal sorry for my used t-5 and clutch!!!!! lol.......i might be doing this swap twice if you know what i mean
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Mar 1, 2008
  • Mar 1, 2008
If you dont wanna splice wires id find the right harness for the reverse lights. Also i would put the neutral safety switch in. The speedometer cable isnt hard to re route . It literally moves 2 inches over. Aod cars have the cabe run through where the clutch cable goes. The spot for the speedometer cable is next to it. I read you have the reverse light connector. That means there should be no splicing at all. Also if you dont have all the wiring for the tranny hooked up the car will not start. There is one wire that runs to the transmission and loops back around. That one wire can cause your whole car not to start. Any other questions feel free to ask Ive done the swap before.
M
Makdaddymac
323
orlando
Mar 1, 2008
#10
  • Mar 1, 2008
  • #10
1)the speedo cable is rerouted, it wasnt that hard, but my concern is it will rub on the clutch cable or steering shaft? what should be done about this, i cant rebolt it to the fram cause then it wont reach!
2)i got talked into installing the neutral safety!!!!! safety first!!!!! so this is just plug and go, but where is this connection at i can't find it in my harness, no piece fits in there. or is it two connections??? what color,s etc etc!!!!!!!
3) and what the hell is the point of this thing with the spring conencted to the rod, i thought the long black platic piece with the spring white knob worked the brake lights! so wtf is this thing.
http://i95.photobucket.com/albums/l133/riceslayer302/mustang project/brakelightswitch.jpg
4)
this is what i have^ im guesing it is a t-5 reverse light coonector, how do i install it to make everything be a complete aod to t-5 swap!
these are the last questions of the swap, which means the next time i work on my car after the pedals are done, i will be slapping gears!
M
Makdaddymac
323
orlando
Mar 2, 2008
#11
  • Mar 2, 2008
  • #11
help me someone,!!
RsStanG1987
569
9
79
Dupont PA
Mar 3, 2008
#12
  • Mar 3, 2008
  • #12
Post in tech and get a more clear picture of that,
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
Mar 3, 2008
#13
  • Mar 3, 2008
  • #13
4)
1) other than it being tight, i had no problems with contact on anything, so i can really help you on that one, other than to say contact with the clutch cable will not hurt it.
2) the connector should be in the big mass of wires up around the firewall. it will already have a plug in it, but it should just be floating around (the plug thats in it just jumps the two wires so that the car thinks the clutch is depressed at all times)
3) the whole assemble in the middle is the brake light switch/master cylinder linkage. the switch on the right is for the cruise control. it turns cc off when the brake is pressed.
4) yes, reverse light harness. plug gray end into harness that was going to the aod, other end goes onto the pair of bass terminals on the driver side of the trans, looks like this http://www.partsamerica.com/Product...IE&MfrPartNumber=NS71281&PartType=401&PTSet=A
M
Makdaddymac
323
orlando
Mar 3, 2008
#14
  • Mar 3, 2008
  • #14
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!GOT EVERYTHING BACK Toghether the correct way, i only ended up with two extra screws!!!!! lol................eveything works, kind of funny having to press a flimsy cluch pedal to start my auto, and i swear everytime i let off the pedal im about to strip the gear or something... never drove an auto with a clutch pedal..lmao....im frigin happy..........
i only have to get a pilot bearing and throw out bearing......
well, maybe a t-5 crossmember and exhasut hanger, cause i get 50/50 on this, some say they are the same, others say you need to mod them, and others say they are so different they are needed to swap!!! i don't know, maybe ford did things different throughput the years to spare inventory. i need someone to verify this, cause its getting close to the t-5 slap in and i want all my parts toghther.
Chuckman
1,604
1,002
173
st. louis, mo
Mar 3, 2008
#15
  • Mar 3, 2008
  • #15
well at lest you got the hard part done now.
on the crossmember, auto and t5 are the same stampings, the only difference is where the crossmember it welded onto the two bolte tubes. there should be 3 tack welds on each side, grind the welds off, beat the crossmember free, and move it back till it lines up with the bolt holes in the trans.
now the exhaust hangers ARE different, but depending on what exhaust you have you can get away without having one. the heavier (or more pieces) the exhaust is the more you'll want the hangers. i was able to leave mine out and just tightened everything up good and snug once i had it where i wanted it.
Darkwriter77
5 Year Member
Jul 1, 2005
314
281
134
Apache Junction, AZ
Mar 4, 2008
#16
  • Mar 4, 2008
  • #16
Again, the thing with the exhaust hanger is how far forward it is in relation to the speedo cable coming out of the T-5. The AOD hanger bracket will contact the cable and make it kind of a PITA to deal with, but you CAN use it without modifying it; however, if you'd just like to make it a bit easier, you could simply hack off half of the hanger on the driver's side (towards the front of the hanger) to allow clearance for the speedo cable and VSS, and still have a perfectly functional hanger. You don't need 4" of nearly solid steel to hold up BOTH sides of the X- or H-pipe ... and, in fact, you could probably just as easily lop off the driver's side hanger altogether and still be just fine.
U
uneedav8
25
#17
  • May 14, 2008
  • #17
Whats the deal with the pin 30 and are you guys using 5 speed computers for the conversion?
blckstng96
208
#18
  • May 14, 2008
  • #18
no need to go to a 5spd computer,computer doesnt control a MANUAL transmission so whats the point.i actually heard the auto comp is better anyway.
where did you get that harness for the reverse lights from?
dbdragracing
397
May 14, 2008
#19
  • May 14, 2008
  • #19
subscribing
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
  • AeroCoupe
  • Aug 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 1:04 PM
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
