hello guys(and maybe 1-2 gals),
i got around to it today,and have majority of it done.now i know i have been asking questions and starting threads but now things are more hands on and make more since.
I got the Aod,tranny lines,tv-cable,auto shifter/cable,and drive shaft out! I tore my old leaky rear main seal out and replaced it!
Got the manual flywheel bolted up, and pilot bearing in. now i just have to figure out how to make room for the t-5 and other wiring stuff. i see where the back up light harness clicks onto the t-5 but have no idea where it connects to, and there is another wire thats already apart of the t-5 that has the same style connection as the harness
under the ar the only thing left is the speedo cable, and maybe one other wire i cant remeber.
my instructions say that i need to open the shifter whole up. but it looks big enough.. if i do have to make space, do i want to cut the hole bigger towards the firewall or towards the rear end. im assumiong its not wider just lengthening the hole!?!?!?!?
as for a firewall adjuster, i dont see how it is gonna help,in fact it looks like it will just adjust loose after some play! but i shimmed of the plastic pieces and sled it over anyway, now i jsut have to find a screw to put in to fasten it to the firewall. but this is where im confused, cause the cable itself has an adjusting nut and i have no idea where to start. do i connect the cable to the quad and pull it completely over or half way
i need help, im very impressed with my overall progress, and will take pics once it is all in. just to prove it to you guys! i havnt posted one pic of my car yet cause i want it to be a red curtain event!!!!!
.......i need help, im very impressed with my overall progress, and will take pics once it is all in. just to prove it to you guys! i havnt posted one pic of my car yet cause i want it to be a red curtain event!!!!!
, but i also installed the mac x-pipe,maybe that made tings easier which i must say sounds like a pissed off bumble bee(maybe i am a hpipe guy afterall) but i have no mufflers!!!!and now im considering magnaflows to quite her down some
