Ok if you look at my previous post I am having a high idle problem....could it be possible {I'm hoping not} that on the lower manifold that the "end "gasket that did not come with my kit,{I was told not to use them but to put excessive amount of Rtv sealent instead} if there was a slight air leak could it cause a high Idle I have checked everything from head to tail the only thing That I have not checked yet is ny O2 sensor's.......I could use some input on this because I really do not want to pull all of that shiaat apart again unless I have too.
http://forums.stangnet.com/showthread.php?t=413661
