Manifold Hoses???????
  • Thread starter Thread starter Haus
  • Start date Start date Sep 3, 2006
H
Haus
408
  • Sep 3, 2006
What are the correct names of the hoses that go into the upper intake manifold.
i need some hoses and not sure on the names or what to ask for.
i need the hose that is on the Source spot on the vacuum tree that goes into the manifold.
the hose that goes from the PCV valve to the manifold. (it's a molded hose)
the other molded hose that goes on the other side where the hose from the PCV valve to the manifold to another part of the manifold.
and a long hose that goes from the manifold down to the fuel evaporated canister(or something like that)
1992 5.0 mustang
HISSIN50
34
129
Sep 3, 2006
  • Sep 3, 2006
You might have to hunt around on a resto site for the correct names. You could get away with bulk line from the parts store as replacements. In an application where you are afraid of the hose kinking (like the PCV), you can use hydraulic line, which has a strong sidewall and resists kinking.
Good luck.
Saleen0679
876
24
49
Yakima, WA
Sep 3, 2006
  • Sep 3, 2006
The manual I have doesn't break the names down. It just calls them crankcase ventilation and evaporative purge hoses. The molded PCV hose is available through LRS.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
Intake vacuum lines
  • cnorman31
  • Mar 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 15, 2025
Scrapla347
