Manifold Hoses???????
Haus
408
What are the correct names of the hoses that go into the upper intake manifold.
i need some hoses and not sure on the names or what to ask for.
i need the hose that is on the Source spot on the vacuum tree that goes into the manifold.
the hose that goes from the PCV valve to the manifold. (it's a molded hose)
the other molded hose that goes on the other side where the hose from the PCV valve to the manifold to another part of the manifold.
and a long hose that goes from the manifold down to the fuel evaporated canister(or something like that)
1992 5.0 mustang
You might have to hunt around on a resto site for the correct names. You could get away with bulk line from the parts store as replacements. In an application where you are afraid of the hose kinking (like the PCV), you can use hydraulic line, which has a strong sidewall and resists kinking.
Good luck.
