Manifold Sensors
federal officer
12
so i'm slowly getting my car back together and have a few questions. I got rid of all the emissions crap and put on a brand new 2121 Edelbrock intake. do I need either of these two sensors and what are they used for ?
What kind of car and what year car did the engine come from? I don't remember anything like that on the 5.0 Fox Mustang EFI engines.
Yeah, that's not for a efi stang, at least not 86-93.. They look like coolant sensors with vacuum ports..maybe for a carb car, but I don't know anything about those
Possible warm air diverter vacuum control valve. It cause warm air to be sucked up from a pipe that is connected to a can or housing around the exhaust manifold. The warm air is fed into the air cleaner to prevent carb icing in cold weather. When the engine coolant warms up enough, it shuts off the vacuum. Then the lack of vacuum causes the diverter actuator diaphragm to close the warm air duct butterfly. Then the warm air ceases to be fed to the air cleaner.
The carb manifold has coolant passages that deliver hot engine coolant to the carb base to prevent carb icing. It only works well with an engine that has come up to operating temperature. That's why the warm air is pulled up from around the exhaust manifold when the engine is cold.
Possible warm air diverter that cause warm air to be sucked up from a pipe that is connected to a can or housing around the exhaust manifold. The warm air is fed into the air cleaner to prevent carb icing in cold weather. When the engine coolant warms up enough, it shuts off the vacuum, the diverter closes and the warm air ceases to be fed to the air cleaner. The carb manifold has coolant passages that deliver hot engine coolant to the carb base to prevent carb icing. It only well with an engine that has come up to operating temperature. That's why the warm air is pulled up from around the exhaust manifold when the engine is cold.
Makes sense
That's only a workable solution if you live in South Florida.
Carb Icing occurs in moist conditions when the temp is in the low 50's F or lower. The pressure drop across the throttle butterflies combined with evaporation of the fuel causes a 20-30 degree temp drop, which puts the temp at the throttle butterflies at or below freezing. The resultant ice causes low speed stumble and drivability problems. The OEM air cleaners had all the plumbing to make this setup work: if you still have it, hook it up and use it.
