Well, I'll be heading home in about a month and all the stuff I need to do to the Stang is starting to make it's way to the front of my brain. First off is the brake swap I'll be doing. I have a set of front disc brakes from a 75 Maverick to put on. I also have a master cylinder and brake booster from an 85 Mustang GT, which I've thought about putting in with ultrastangs website. However, I was wondering if anyone has put these brakes on without the booster. Since that would be one less think I would have to work with since the engine will be in the car. If I went without a booster, which one would I use?
Also, to use the Maverick spindles I'll have to change the tie rod ends right? I have a set of spindles from a 71 Mustang that look just like the Maverick spindles. But I won't have to change the tie rod ends or anything else. Can I just put the brake parts on these spindles?
One last thing, since I'm going to have to change the rubber lines, I was thinking of going with braided lines. Does anyone have them and if so, where did you get them?
Thanks.
Thanks.
