Electrical Manual swap: Neutral Safety Switch and Reverse Lights ??
Chaseskywalker
Indiana
Hi all, I recently bought a 1999 Mustang GT body that had an automatic in it, along with a 4.6l engine and T45 transmission out of a 2000. I've pretty much gotten all of it together, but from what I understand, I have to do some splicing to get the reverse lights to work, and also jump the neutral safety switch on the automatic transmission harness so it will start with the manual. But, I can't find anywhere that says which wires I have to splice/jump for either. Can someone that's done this before help me out?
wmburns
SN Certified Technician
Aug 14, 2009
5,294
409
164
Houston Texas
On the connector where the automatic DTR range sensor is place a jumper between the RD/LB (pin #10) and the WH/PK (pin #12) to bypass the automatic transmission NSS circuit.
This is also assuming that the jumper around the clutch pedal position switch has been removed and the clutch pedal switch has been installed.
wmburns
Aug 14, 2009
5,294
409
164
Houston Texas
Reversing lights at C110 DTR sensor connector
VPWR OG pin #9
Reversing circuit BK/PK pin #11
Wire the manual transmission reversing switch between pin 9 and 11.
Chaseskywalker
Indiana
Thanks, that's exactly what I needed. One more question, on the Automatic Transmission harness, theres the 3 O2 sensor plugs, the VSS, the Transmission range Sensor, but then there's a white plug that looks like the O2 sensors but bigger with 6 or 8 Pins on it. Do you know off hand what that's for? I can get a picture later if that helps
wmburns
Aug 14, 2009
5,294
409
164
Houston Texas
It sounds like you really need a full set of Ford wiring diagrams and service manual for your car. This is where I get my information from.
If interested in getting a copy for yourself I maybe able to help. PM if interested.
