manual to 4r70w guys in here please
belzebub2u
164
Woodstock GA
heya guys, gettin my tranny worked out, but i have a couple questions, im goin from my 5speed to a 4r70w and i need to know a couple things. can i run a stock flexplate for the 3v engine, or will i have to run one from a 4r70w car? also the driveshaft, does someone make one, or will i have to custom make one. if custom, what is the length it needs to be? i have a DS shop close to the house, just need to know the length. also what shifter are you running, i have only found 1 shifter that says it will work. is it possible to make http://www.tciauto.com/WhatsNew/Files/tcistreetfighter05-08mustangratchetshifter.pdf work with the 4r70w? i hope so, it looks sweet.
I'll let someone else handle the other stuff, but I can tell you that shfter will not work with a 4R70W, only with a 5R55S.
That is, it should work with a 5R55S, if they ever actually release it!
