I have a 99 Mustang with the Mach system and I'm trying to figure out the best way to install. Hopefully you can help me with a couple questions:
1. I have a Kenwood head unit. I've seen two different types of wiring harnesses: one is cheap ($15) and one is quite a bit pricier ($50). The latter one says that it will keep the stock amp working...is it worth it? Where should I buy?
2. What have you guys done with the lower CD player when adding an aftermarket HU? I'm sure you could put an equalizer or changer in, but is there something more simple that can be put down there? Maybe a sunglass holder? If any ideas, where to look/buy?
3. I have two JL 10s that I used in a different car. The box they were used in is a simple, cheap, sealed box. It's too tall and a little bit too wide. I don't have the ability to build a box and am looking for an affordable solution (custom probably too $$$). Any ideas of places to look?
4. I've seen some boxes that I could use if I faced the subs straight up at the deck. Any problems doing it this way?
5. Finally, what is the best repair manual out there for Mustangs? I'd like to have something to reference when tearing my car apart.
Thanks in advance.
Thanks in advance.
