Map sensor issues
  • Thread starter Thread starter 1990Coupe
  • Start date Start date Jun 24, 2006
1990Coupe
1,462
132
114
Toms River NJ
Jun 24, 2006
  • Jun 24, 2006
So im finally getting the car on the road. I had a couple of problems and pulled a couple of codes... One was the map sensor and EGR.. so i decided to go the easiest route (when the car is warm, if push in the clutch, it idles realllyyyy low, and most time dies) and replace the map sensor. so i picked up a used one from the mustang junkyard close by me, and when i went to install it, i noticed the one in there had a hose coming off the left side of it running to the vaccum tree? i thought map sensors didnt have this, so i installed the new one i got, and plugged the vac tree, now when i start it, it will revv to 1500 and die. then ill re-start it, it will revv and ill help it idle but she idles at like 400? is that line susposed to be hooked up to the map sensor??
A
ARTTII
272
Detroit, MI
Jun 24, 2006
  • Jun 24, 2006
are you running mass air or speed density?
xpeteyjtx
108
Taunton, MA
Jun 24, 2006
  • Jun 24, 2006
If you have mass air, you might need a different unit... or you may be able to use the speed density unit without the vacuum line (I am not sure). I also got a MAP code (I believe it was 33, but not sure). I purchased a new one from ford, $100-$150, installed it, and I don't think I noticed any difference in the way the car ran. I think I even drove the car without the MAP plugged in and it was fine.
T
TENGRAM
143
  • Jun 24, 2006
i think it should be fine as long as you hook up the vacuum line. what you got was a BAP from a mass air car. your car came with a MAP but i think they are interchangeable
1990Coupe
1,462
132
114
Toms River NJ
Jun 25, 2006
  • Jun 25, 2006
The car is a mass air car. so pretty much i should hook the vac line back up off the tree?? Still i thought that map sensors didnt have a vac line coming off of them?
xpeteyjtx
108
Taunton, MA
Jun 25, 2006
  • Jun 25, 2006
I am pretty sure that Mass Air cars do not use the vacuum line. Mine doesn't and it is a 91. Whether or not the units are interchangeable though, I do not know. Just try it out and if you get the same code, then you know you have a problem. Make sure you reset the computer.
1990Coupe
1,462
132
114
Toms River NJ
Jun 25, 2006
  • Jun 25, 2006
Ok i pulled the codes and im not showing a map sensor anymore. and the engine light as gone off. I think that it didnt want to idle for me possibly because the codes had been cleared, i reset the ECU and with the heads, x cam and intake it was just re adjusting itself. seems to run fine when its all warmed up, ill let it cool and try to restart and see if i have any idle issues when cold. Thanks everyone!!
1990Coupe
1,462
132
114
Toms River NJ
Jun 27, 2006
  • Jun 27, 2006
so the car idles fine. the computer just had to relearn everything!
T
TENGRAM
143
  • Jul 1, 2006
M
Map sensor
  • miser143
  • Aug 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
AeroCoupe
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
