map sensor question
  • Thread starter Thread starter noslow1986
  • Start date Start date Nov 13, 2006
N
noslow1986
274
oswego Il
Nov 13, 2006
  • Nov 13, 2006
went to autozone to see about a map sensor. i need one w/o vacuum line i switch over to mass air, could i just cap it off i know the 90 and 93 dont have the vacuum line auto zone said there all the same the all have the vacuum port.
HISSIN50
34
129
Nov 13, 2006
  • Nov 13, 2006
Seems to me that when guys do the MAF conversion and the MAP becomes a BAP, you'd just leave the sensor uncapped (so it senses atmospheric pressure).
71swing
199
Omaha,NE
Nov 14, 2006
  • Nov 14, 2006
I did the convertion not to long ago. They say there is a difference with the two sensors, But they do look same, and both have the vacuum ports. When you purchase a 89-93 map sensor it will include a little rubber grommet to prevent a vacum line going on. When I did the switch over I went ahead and bought the new sensor it cost about 40$.
With the car running I simply switched between the old to the new sensor I could tell a difference in the idle qaulity. It seemed to idle better with the calibrated sensor.
M
Map sensor
  • miser143
  • Aug 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
AeroCoupe
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
