MAP sensor
  • Thread starter Thread starter BAHRAINI_STANG
  • Start date Start date May 8, 2007
BAHRAINI_STANG
69
  • May 8, 2007
hi , i have check my engine vucuum line and i found the MAP vucuum line is missing ,wheres the source must be connected to MAP sensor
THANKS
bill302
2,131
alabama,gadsden
May 8, 2007
  • May 8, 2007
it connects into the underside of the intake manifold..
vristang
4,933
101
124
Seattle
May 8, 2007
  • May 8, 2007
BAHRAINI_STANG -
You are running a MAF ecu aren't you? I thought you had the A9L or XOX ecu?
If that is still the case then your MAP sensor is actually used for measuring the Barometric Pressure, making it a BAP sensor.
The BAP should not be hooked up to manifold vacuum. Just leave it exposed to atmosphere.
Drop me a pm, or let us know how the project is going. Haven't heard anything in a while...
good luck,
jason
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 8, 2007
  • May 8, 2007
If you have an 89 or later model car, your car will have a mass air computer. Mass air cars use the same style sensor, but call it a Baro sensor. It vents to the open air. There is no vacuum line to connect it to the intake manifold for a Baro sensor.
BAHRAINI_STANG
69
  • May 9, 2007
vristang said:
BAHRAINI_STANG -
good luck,
jason
HI vristang,thanks for asking ,my stang in home i did aod to t5z conversion ,full suspension ,rear end ,manual rack,
next week i will start my HCI gt40p +tfs1+ edel 5.0 WITH fresh build 306.
for xox ecu still in my stang i will install an o2 sensor for this ecu and i check it respond
vristang
4,933
101
124
Seattle
May 9, 2007
  • May 9, 2007
It's good to hear your still making progress and that you finished the t5 conversion
Keep us posted on how that X0X responds, I am still pretty curious about that ecu.
Good Luck,
jason
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
M
Map sensor
  • miser143
  • Aug 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
AeroCoupe
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
