  • 1994 - 1995 Specific Tech
mark 8 fan hookup
  • Thread starter Thread starter 94gtslow
  • Start date Start date Jun 24, 2007
9
94gtslow
401
Temple,Texas
Jun 24, 2007
  • Jun 24, 2007
got a mark 8 fan.
anyways, i was going to hook it up with a 30 amp relay and a inline 30 amp fuse for each, 1 for the high speed and one for the low speed. with an on-off-on switch.
Will this work?
HISSIN50
34
129
Jun 24, 2007
  • Jun 24, 2007
No.
The Mark VIII pulls over 100 amps for milliseconds during ramp up. That little relay will shoot poo all over itself in a short amount of time (and inductance will wipe out the Normally Open contact anyhow).
For the easy way to do it (and a real nice way in hot Texas), use a DcControl unit. Other guys (Urban for one) have had good luck with the SPAL controller. FAL also makes a decent controller but I'm not sure it can handle the Mark VIII.
If you really want to do this using your own relays, At a minimum, I would get a Bosch 75 amp relay for high, and use the factory input to the HEDF relay for your new fan. Even better is to get two 75 amp relays and do this for both low and high. The will be controlled like stock but use HD relays instead. This will last a lot longer. Of course, by the time you buy two 75 amp relays, you're well on the way to a quality controller (though with the SPAL and maybe FAL, you still need a high speed relay IIRC. With DcControl, you do not).
No matter what relay you use, the flyback diode is a good idea.
Random thoughts.
Good luck.
9
94gtslow
401
Temple,Texas
Jun 24, 2007
  • Jun 24, 2007
so what the best way to hook it up manually?
just use 2 75 amp relays,1 for higth, and one for low spped.
This is going on a 98 cobra motor in the fox so it has the 130 amp alternator.
HISSIN50
34
129
Jun 24, 2007
  • Jun 24, 2007
Actually, the easiest way is to use a Dc Controller. It's along the lines of a 5 wire hook-up. Because there are no relays, it makes the wiring really easy.
Two 75 amp relays will work fine. You really would probably want a temperature sensor of some sort unless you like flipping fan switches non-stop.
Knowing exactly what you demand of the installation would help us to make suggestions. For example, a Dc Controller on a 1320 car (only) would be a waste. But on a street car, using mechanical switches with no controller could be a disaster.
9
94gtslow
401
Temple,Texas
Jun 24, 2007
  • Jun 24, 2007
the 90 is not a dd, its a drive to the track and back car, and cruise.
HISSIN50
34
129
Jun 24, 2007
  • Jun 24, 2007
It's really up to you then. The two 75's would be robust. You could try to save a few bucks and use a 50 amp Bosch relay (they cost like 6 bucks instead of 20-25) for the low speed.
For a very complete write-up on such an install, see this Mark VIII install article.
As I mentioned, figure out all your parts costs before ordering and compare that to using a Dc Controller. I did this with a friend whom was going to use relays. With his chosen controller, etc, it was going to be 92 bucks. It was a no brainer to just use the Dc Controller instead.
Good luck.
SJB Parasitic Draw, Fuse 59&67
  • 2005 Mustang V6
  • Apr 30, 2026
2005 - 2014 S-197 Mustang -General/Talk- Tuesday at 1:13 PM
boatillo
D
1999 G/T 4.6 A/C clutch not engaging.
  • David B.
  • Apr 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 8, 2025
David B.
D
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
J
89 mustang alarm install to lock and unlock
  • jk66
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2026
jk66
J
84 turbo fan not working.
  • bdub_mkg
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 2, 2026
AeroCoupe
