Yep... I've heard of it.
Yes.... They work.
What you're doing is electronically "squeezing" the feedback from the meter element into a 5 Volt sensing range.
In other words: You're changing the Mass Air Flow Transfer Function of the meter which means you will need to remap that transfer function through either a custom chip or ECU tuner.
Folks that have meters that "Peg" use these things because feedback readings higher than 5 Volts are useless to our EEC.
