I bought a mass air kit off ebay which I believe is stock 88-93. I threw the computer in after making the wire changes. Then I installed the new tube with the sensor. Lastly, I disconnected the vaccum to the map sensor and plugged it off. At fist it seemed to run pretty good. Eventually it idled terribly. In fact it wouldn't stay running at all. I suspect the mass air don't like the 24lb injectors I got. (I changed it back to speed density for the meanwhile, but with the changes I've made , I don't like cause it just seems to idle fast.) I read that if I adjust the fuel pressure down a little, that'll fix the problem. To do that, I'll have to buy an adjustable regulator. Would I be better off buying a different sensor? Could it be a another problem I missed?
1987 Mustang GT
5 speed
HO 302
stock cam
stock intake
24 lb injectors
gt40 heads
gt40p headers
x-pipe
2 1/2" flowmasters
1987 Mustang GT
5 speed
HO 302
stock cam
stock intake
24 lb injectors
gt40 heads
gt40p headers
x-pipe
2 1/2" flowmasters
