MASS AIR METER
  • Thread starter Thread starter GREG91GT
  • Start date Start date Jun 30, 2004
GREG91GT
207
MISSOURI
Jun 30, 2004
  • Jun 30, 2004
yes i have a ? has any of you ever ran your car without the mass air meter hooked up i did accidently wanted to see how your car acted compared to mine?
Bladez5_0
460
Goose Creek, SC
Jun 30, 2004
  • Jun 30, 2004
You can run it just fine without a MAF but the car will run rich. The computer reads the fact that the MAF is not there and assumes a certain amount of air flow and runs a preset Safe mode to prevent the car from running lean and detonating.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jun 30, 2004
  • Jun 30, 2004
yep, i accidentally didnt hook mine back up after my intake install. drove around for 2 weeks without it hooked up. it ran fine, but yeah it did run rich
GREG91GT
207
MISSOURI
Jun 30, 2004
  • Jun 30, 2004
mass air
mine keeps falling on its face when i smash it to the floor,i also have 30 pound injectors, i kind of wonder if my mass air meter is the problem?
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jun 30, 2004
  • Jun 30, 2004
stock mass air meter with 30 lb injectors? whats the rest of your setup like?
GREG91GT
207
MISSOURI
Jun 30, 2004
  • Jun 30, 2004
c&l
no i have a 80mm c&l for 30s i have edelbrock heads,systemax intake, 75mm throtle body and spacer, and 1inch intake spacer,255lph holley pump,dss dish pistons,no ac,no ps,no smog pump,electric water pump drive,1 3/4 mac long tube headers, and a vortech s trim and fmu, s-trim not bolted on yet and a built c-4 with a 8inch ptc converter and pro stick shifter
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jun 30, 2004
  • Jun 30, 2004
check your tps voltage. hopefully jrichker will see this and throw out some numbers for the voltage. i believe it should be under 1 volt at WOT. dump some codes and we can help you out if you dont have a book
88stangmangt
2,332
Stafford,VA
Jun 30, 2004
  • Jun 30, 2004
c&l has been knw for there ****y mam's. i am gonna use a blow thru (not sure what brand) with my Blow Off Valve.
GREG91GT
207
MISSOURI
Jun 30, 2004
  • Jun 30, 2004
no my c&l was not hooked up
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jun 30, 2004
#10
  • Jun 30, 2004
  • #10
oh yeah, totally forgot about that
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
