Who's gottem' and what brand? Any problems or work great? Let's hear about them. For what size injectors and what set up.
Who's gottem' and what brand? Any problems or work great? Let's hear about them. For what size injectors and what set up.25thmustang said:Stock with stock injectors, hasent been an issue yet but I think my Pro M 75 I will be getting will help the car some!
My 75mm bullet is flat black!Highbredcloud said:If you haven't gotten the 75mm bullet than I suggest you take a look at the pro-M 80mm or even the 77mm...you will be much more satisfied with either over the 75mm bullet...unless you want the looks of chrome under the hood...
they do make ones in chrome as well...your is probably the thick plastic one used on the Pro-M 80mm...if you ever going to upgrade the car h/c/i you may want to step up in the MAF department...willys1 said:My 75mm bullet is flat black!
25thmustang said:Well Im getting it for $100, and for both classes I plan to run in the future (NMRA Factory Stock/ and Real Street) I have to run 75mm or less. That means no C&L 76, no Pro M 77 or 80s. I figure they cant be that bad can they?
yup,,,it matches the rest of my cai--( Dense Air Charger )Highbredcloud said:they do make ones in chrome as well...your is probably the thick plastic one used on the Pro-M 80mm...if you ever going to upgrade the car h/c/i you may want to step up in the MAF department...
