Mass Air sensor question...
  • Thread starter Thread starter Vinnietbird
  • Start date Start date Nov 5, 2007
Vinnietbird
584
  • Nov 5, 2007
Will a Mass Air sensor from a V-6 work on a V-8 if the injectors are the same size between the two engines?
jake2582
107
tallapoosa
Nov 5, 2007
  • Nov 5, 2007
yes
Vinnietbird
584
  • Nov 5, 2007
Thanks a lot.
jake2582
107
tallapoosa
Nov 5, 2007
  • Nov 5, 2007
i might be wrong* sorry
vristang
4,933
101
124
Seattle
Nov 5, 2007
  • Nov 5, 2007
It depends on what vehicle the meter was pulled from...
Has nothing to do with the injector size, when you're dealing with Ford meters. (aftermarket meters are cal'd for injector/ecu though...)
A meter from a 94-95 v6 Mustang will be the same as the meter on a 94-95 v8 Mustang.
Let us know more details on what you have...
part numbers if you have them.
jason
HISSIN50
34
129
Nov 5, 2007
  • Nov 5, 2007
jason
Vinnietbird
584
  • Nov 6, 2007
I don't have the sensor yet.I found that a Ford Taurus with the Duratech V-6 runs the type 3 24# injectors (I'm using Explorer 19# type 3 injectors now).I pulled 12 all together and then I got to wondering,will the sensor for the Mass Air meter work with these injectors on my car,assuming that the sensor will fit as it's supposed to on my Mass Air meter (which is a Cobra 70mm meter).I'm not exactly sure of the year of Taurus.
vristang
4,933
101
124
Seattle
Nov 6, 2007
  • Nov 6, 2007
Let's confirm what you will be using...
1. Injectors will be 19Lb
2. ecu is an A9L/A9P/A3M/A3M1/etc?
3. 70mm Cobra MAF housing
For this to work you will want to put a F2VF sensor in the Cobra housing.
That *should* work the same as a 94-95 Mustang MAF/MAS setup.
I can't confirm that though.
The F2VF sensor can be found on several vehicles in the j/y's...
Black1987Stang
1,422
Jersey Shore
Nov 6, 2007
  • Nov 6, 2007
Certain year taurus's with the 3.8 V6 engine (the 3.0's they use a smaller meter opening) maf will work as I've taken at least 3 off em in the junkyard and they worked the exact same as my factory one.....since they both have the same part number. but I'm talking about the meter and housing is the same, it probably wouldn't work right in a bigger housing.
Vinnietbird
584
#10
  • Nov 6, 2007
  • #10
I plan on installing my E303 cam,and 24# injectors.I have the A9P and 70mm Mass Air meter.I'll need a sensor to use for the 24# injectors.
N
n2o-89fox
116
ca
Nov 6, 2007
#11
  • Nov 6, 2007
  • #11
I have the same meter and found out on the cobra forum that the meter is calibrated for the 19 # injectors and the computer adjusts for the 24# injectors. So unless you have a tune for the injectors that meter will not compensate for the 24's. The part number on mine is F2VF-12B579-A1A.. oh forgot to put it is a 94-95 cobra 70mm
Vinnietbird
584
#12
  • Nov 6, 2007
  • #12
Thanks a lot.I needed that.LOL.
vristang
4,933
101
124
Seattle
Nov 6, 2007
#13
  • Nov 6, 2007
  • #13
It is important to understand this...
Ford sensors are not calibrated for an injector size.
Ford calibrated the output of the MAF/MAS unit to an ecu.
With that said...
... You won't find a sensor that will allow you to run 24's on an A9P, using that MAF tube.
There are options...
1. Custom tune via the J3 port
2. Use an X3Z ecu, 24's, and the 93 Cobra MAF/MAS unit
3. Use an aftermarket MAF meter that is calibrated for the A9P and 24's
If it were my car, I would go with option 1 or 2.
jason
Vinnietbird
584
#14
  • Nov 7, 2007
  • #14
I may get a custom chip for it.There's a shop just west of me that can do that work.He's all about the Stangs and 5.0's.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
Electrical Stumped No Start...
  • sydhawk
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
sydhawk
