mass air with blower question
jrockhall
35
I have a mass air meter calibrated already to work with bigger injectors if I put on a blower will the mass air work with it or will i have to get it calibrated again to work with the blower?? Thanks.
it'll work. you need to decide it it going to be a blow through (on the pressure side).. you can call your mass air meter manufacturer and they will tell you what works best. you might need to clock the mass air meter aswell, in some applications the meter works better at different angles,(depending the airflow characteristics in the tube where the meter is.
hope this helps
Dieter.
