mass air ?
blue87stang
25
San Antonio Tx
So i have trying to get my car up and running and doing so when i have time.. It does like to cold start at all i mean it dies and pops and once it worns up it surge idles some but anyways heres my ? Im am using a 80mm mass air housing from my 01 that i sold. Its a c+l and its got a 19 pound tube in it. The a9 should work ok with this mass shouldnt or does it cause problemsss?
Thanks
brian
TenorPlayinGuy
1,208
Canyon Country, Ca
If its surging you should check other things first.
Check the firing Order,
13726548 for a stock 5.0
^ Front of car
5 1
6 2
7 3
8 4
On the distributor The number one goes... (YOU GUESSED IT!!) Number one cylinder. From ther go counter Clockwise and wire it up with the firing order 1,3,7,2,6,5,4,8.
Fiddle with the timing a bit and get it to run.
From there you can assume its a worse problem.
I only speak from experience that problems that include a major surging at idle and popping., Has to due with firing order and Timing.
Make sure the number one cylinder is at TDC for the Power Stroke. NOT TDC Intake. Otherwise you will be off by a good 90-180 degrees which will also make it surge like crazy.
As for the mass air meter, Im not sure about the compatibility with OBD-II components and our OBD-I Fox Bodies. I use a PRO-Flow 24# mass air meter with my A9L.
Also check for Fuel pressure, and resistance in the injectors. I believe the stock resistance should be between 14.5-15 Ohms of resistance, If Im wrong please correct me I don't have a Service manual on hand.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,513
2,854
234
Dublin GA
You guys with idle problems could same a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first post has all the fixes, and steps through the how to find and fix you idle problems without spending a lot of time and money. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix.
