ok so what do I need to convert it to a maf?what type of computer and what does it connect to.is it the engine control computer?
a 86 mustang has flat top pistons. Depending on head selection you will have to see what lift cam you can run with trickflow heads on my stock 86 short block I was only able to run .512 lift. I clayed it to check, it will vary motor to motor. Injectors will have to be picked after you decide what to run. 70 mm throttle body is good on NA 302.
I'm gonna buy a gt40 intake with non egr.thanks..now about the egr system.if I remove it and swap to a maf will it mess anything up by removing it?
I've always been into chevys so not to familure with fords.first of I want to know if I can keep the lower intake on and what uppers will fit with the stock lower.and is the gt40 lower and upper better then the stock 86 intake?would a aftermarket upper bolt on to the lower intake?thanks
