Master cylinder went out
That's the brake light switch. These master cylinders are easily available, but if you want increased safety, use a stock 67 drum brake master with your 64 pushrod. You'll have to move the switch to the part of the divider block now used by the rear bake line (which will be connected directly to the master cylinder). That will requires a brass adapter, since the hole is an inverted flare and the switch is a pipe thread.
can you send me a picture of what that looks like?
