matching numbers
  • Thread starter Thread starter asiantony
  • Start date Start date Jul 14, 2006
A
asiantony
  • Jul 14, 2006
hi guys,
i've got a 66 fastback with a 289. how can i tell if it's the original engine that came with the car? where are the numbers stamped on the block? how do they correlate with the VIN numbers? any help is much appreciated!
D
D.Hearne
11,730
south louisiana
Jul 14, 2006
  • Jul 14, 2006
No vin numbers on a 65. Look at the casting numbers above the starter, there you'll find the casting and date code. Date code is a number/letter/number(s) combination. 1st number is the year of the decade it was cast, the letter is the month code starting with A and aphabetically to M for december, they skipped the letter "I". The 3rd number or numbers is the day of the month it was cast. The decade is determined by the first two numbers of the casting number. Yours should be a C4 or C5, most likely C5
A
asiantony
  • Jul 15, 2006
same thing applies to 66 mustangs?
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Jul 15, 2006
  • Jul 15, 2006
Yes, except the casting codes could begin with either a C5 or a C6.
BarnStang
1,260
Hagerstown, MD
Jul 15, 2006
  • Jul 15, 2006
You can decode the whole number here:
http://www.mustangsandmore.com/ubb/FordTechData.html
But you can't take this as written in stone. Iv'e been told that they could put engines from other lines in the Mustang if they ran out and had cars to finish? So you could have an engin coded for a Falcon or a Fairlane, but was put in on the assembly line. Don't know how accurate that is...
D
D.Hearne
11,730
south louisiana
Jul 16, 2006
  • Jul 16, 2006
The product line the block was cast for means nothing. I don't believe there's any "Z" coded blocks in 289's. They're all either "O" or "A" in the third character. Just because the third character denotes one vehicle, doesn't mean that's the vehicle it was installed in. That's the case maybe half the time. Ford never cast one particular engine block for one particular car. Take for instance the 428 CJ, the block casting numbers says it's a Mercury block, but there were more of these engines put into Stangs than Mercs. Same was true for the late 5.0 roller blocks, so far I've seen 2 casting numbers for these, E6SE and E7TE, but they can be found in any 5.0 application, be it car or truck or van.
A
asiantony
  • Jul 17, 2006
well, i've got a 1966 fastback with a 289. not sure if it's the original engine, but more than likely it is. how important is it to preserve the original engine? i really feel the need for a 347 stroker.
D
D.Hearne
11,730
south louisiana
Jul 17, 2006
  • Jul 17, 2006
Well if you want top dollar for the car, it might pay to button up the 289 to keep the critters out and store it. Get a roller block for the 347.
BarnStang
1,260
Hagerstown, MD
Jul 17, 2006
  • Jul 17, 2006
Means nothing? Pretty harsh even if true. I think I conveyed that the info I provided was not reliable. I was just trying to provide the guy some info-which is what he asked for. Not everyone will have a perfect answer all the time. No reason to dump on them...oh, I have seen a CZ block. My boss has a hi-po block in cold storage. THey are few and far between.
D
D.Hearne
11,730
south louisiana
Jul 18, 2006
#10
  • Jul 18, 2006
  • #10
I didn't mean for it to sound harsh. You took that the wrong way. It's just that many seem to think the product line code means that a block cast for say, the Galaxie line would only be found in a Galaxie. And yea, the Boss block would be an exception, I thought about that afterward. But a Boss 302 block wasn't cast for a 289. It was cast for the Stang line, but not for 289's.
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
T5 identification
  • 3054tony
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
AeroCoupe
