  • SN95 4.6L Mustang Tech
max boost
  • Thread starter Thread starter fast97gt
  • Start date Start date Jan 7, 2007
fast97gt
1,082
north carolina
Jan 7, 2007
  • Jan 7, 2007
got a 97 gt (mods below) with stock internals what s/c and max boost would you all recommend
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Jan 7, 2007
  • Jan 7, 2007
10psi
the98stang
2,408
Clovis, CA
Jan 7, 2007
  • Jan 7, 2007
Just keep the power levels under 450WHP and get a conservative tune.
Remember every car reacts differently to boost. Two of the same cars with the exact same mods/power can get different HP gains with the same amount of boost.
04YELLOWGT
1,135
Indiana
Jan 7, 2007
  • Jan 7, 2007
10 psi or less. I would add an intercooler too. More power and safer.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 7, 2007
  • Jan 7, 2007
its not the boost that kills engines its the tune. you can blow a bottom end out at 300 hp it the tune is bad.
i'd say keep it under 12 psi and 450 hp
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Jan 7, 2007
  • Jan 7, 2007
id say start small and work your way up. do 8psi tuned for now, non-intercooled if you dont have enough money for the intercooler. then get the intercooler and bump it to 10psi and dyno time. then depending on your fuel system and whats going on in the dyno (if youre getting lean or the tuner cannot run much timing due to predetonation/knock) then id say bump it up more till you find the edge then pull back some.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 7, 2007
  • Jan 7, 2007
kinda hard to pull back some when you have a rod broken into little pieces
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 7, 2007
  • Jan 7, 2007
Somehow, I don't think he's gonna have to worry about seeing 450hp with a stock non-PI long block anyway......regardless of how hard he pushes the blower.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 7, 2007
  • Jan 7, 2007
i didnt see that he was non PI. you should be fine with 12 psi as long as you have a cooler.
fast97gt
1,082
north carolina
Jan 7, 2007
#10
  • Jan 7, 2007
  • #10
yea not doin anything p/i yet looking for a doner 2v engine to build s*** out of then prob twin turbo undecided still
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 7, 2007
#11
  • Jan 7, 2007
  • #11
fast 97, what part of NC are you from. i have some extra parts if you are looking to build an engine
fast97gt
1,082
north carolina
Jan 8, 2007
#12
  • Jan 8, 2007
  • #12
lil ol town of denver between charlotte and hickory, what you got?
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 8, 2007
#13
  • Jan 8, 2007
  • #13
i'm in four oaks. its a little town just north of where I95 and I40 cross.
fast97gt
1,082
north carolina
Jan 8, 2007
#14
  • Jan 8, 2007
  • #14
what do you have i might be interested saleen gt
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 8, 2007
#15
  • Jan 8, 2007
  • #15
i've got a few parts i bought that i will not be using. i have a 4.6 romeo block .020 over. i will have the entire short block from my car for sale in the coming months. i have a complete 4v setup that i will not be using, 01 cobra heads. the 6 bolt aluminum flywheel currently in my car.
some of these might be useful if you are planning on building an engine in the future.
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Forced Induction Vortech bypass valve necessity
  • 92Rustang
  • Aug 28, 2024
Fox 5.0 Mustang Tech Sep 2, 2024
Cheapskate207
Airaid reduction sleeve?
  • BriansNSane
  • Dec 20, 2025
SN95 4.6L Mustang Tech Dec 20, 2025
BriansNSane
  • Gulftown980x
  • Jul 29, 2026
squeak93
