  • SN95 4.6L Mustang Tech
Maximum Motorsports Steering Shaft
  • Thread starter Thread starter redmustangt
  • Start date Start date Jul 22, 2009
R
redmustangt
33
  • Jul 22, 2009
I was thinking about buying the MM Steering Shaft. I wanted to know if it was the same size as the factory shaft or is it slimmer/wider? My factory steering shaft is pretty close to my headers. They dont contact each other but they are very close together.
R
rjs281
51
deer park tx
Jul 22, 2009
  • Jul 22, 2009
It should be fine.It fit great(i do have LT"S )on mine and wasn't hard to install.You well be tell how much better it fells without that rag joint.
Skud
493
Saskatchewan
Jul 22, 2009
  • Jul 22, 2009
The shaft itself is slightly "beefier" than the stock unit. However, you get rid of the rag joint. So, if that's where you're close to hitting then it will get you more clearance.
I have MAC longtubes with the MM steering shaft and it does not hit anywhere. If you go with the MM unit you don't really need to worry about it being close. It's solid metal so it won't get too hot and break like the stock part.
Riley
J
jegg
106
  • Jul 22, 2009
What is this "rag joint" and what is the advantage of swapping out to a MM steering shaft?
Flghtmstr1
572
Springfield, PA
Jul 22, 2009
  • Jul 22, 2009
Rag joint = rubber and fabric joint which allows u-joint-like flexibility plus shock absorption at the expense of steering feel
MM steering shaft = aftermarket steering shaft which replaced rag joint with u-joint, providing crisper, more direct steering and improved feedback, but at the expense of transmitting unwanted as well as wanted vibrations
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Drivetrain Tail Shaft bore odd shape
  • R82148V
  • Jun 12, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Mustang5L5
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
A
Engine 99 V6 Steering Pump Replacement
  • abs68206
  • May 23, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2025
abs68206
A
