Well I upgraded my ground connections and advanced my timing a few degrees and it feels like a whole new car. The idle is rock solid, if not a tad high (around 1000-1050 rpm). And I have a lot more power. Spin em through second and chip third. Throttle responce is way better too. I have a spacer plate on the IAC that I monkey'ed with extensively trying to fix the surge so I think I can get the idle back to normal with that (Im guessing the screws are adjusted to tight). Guess what they say is true, you can never have too many grounds
::EDIT:: I have a really crappy timing light so Im not 100% sure what I initial timing was set too. I think its around 15deg. If its advanced too far I know I'll get pinging but Im not really sure what that sounds like. Does it happen across the rpm range or in specific ranges if your advanced too much? What does it sound like? Sorry kinda newbie'ish questions I just dont want to break anything
