May have fixed surging idle...
Skoobie
Damn...Tyler65's hot!
May 25, 2003
655
Vancouver, WA
Well I upgraded my ground connections and advanced my timing a few degrees and it feels like a whole new car. The idle is rock solid, if not a tad high (around 1000-1050 rpm). And I have a lot more power. Spin em through second and chip third. Throttle responce is way better too. I have a spacer plate on the IAC that I monkey'ed with extensively trying to fix the surge so I think I can get the idle back to normal with that (Im guessing the screws are adjusted to tight). Guess what they say is true, you can never have too many grounds :D :nice:
::EDIT:: I have a really crappy timing light so Im not 100% sure what I initial timing was set too. I think its around 15deg. If its advanced too far I know I'll get pinging but Im not really sure what that sounds like. Does it happen across the rpm range or in specific ranges if your advanced too much? What does it sound like? Sorry kinda newbie'ish questions I just dont want to break anything :)
snoboardcore said:
another thing you can do for a surging idle that my buddy did was port your IAC but just barely. Now his car has no surging what so ever.
I was going to ask about that. Like I said I have one of those spacers with the allen screws that lets you adjust the air flow at idle. Its suppose to eliminate the surge. I had heard about opening that gap in the IAC but I thought that was just the cheap do it yourself version of the idle plate? What happens if you have both? I dont really want to start taking material off the IAC if its not going to do anything...kinda hard to put that stuff back on. hehe
Well I went out for a run to see if there was any detonation but things seem ok. The idle hangs between shift though then settles to around 1k or so. What would cause the hanging? Also I tried to adjust the idle plate to bring the idle down to 800 ish but nothing happened. I unplugged the IAC to see what would happen...again nothing happened. What SHOULD happen if you unplug the IAC? I thought it would die.
Have you been through the Surging Idle Checklist Sticky?
Not sure what you mean by the hanging rpm between shifts, but the computer will keep the rpms a little higher when the vehicle is moving. Just a couple hundred rpms though.
If I push in the clutch in while moving the idle stays at X or even raises up a couple hundered RPM above X before it settles back down slowly. Thats a new one. I have gone over the list. I actually replaced the IAC after cleaning my old one and breaking off the ear after over torqing. The problem is though that absolutely NOTHING changes when i unplug the IAC. What should the voltage be in the connector? I havent tried that.
Do yourself a favor - Carefully read the sticky "Help me create the Surging Idle Checklist" at the top of the forum for help with your idle problems. The first most contains all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
It also gives specific information on how the IAC operate. It spells out what the voltage is and what the waveform that the computer uses to control the IAC is like.
