Measuring Hood Clearence?
  • Thread starter Thread starter soontobefastfox
  • Start date Start date Oct 15, 2006
soontobefastfox
275
Troy, Michigan
Oct 15, 2006
  • Oct 15, 2006
How do you measure hood clearence? I tried to and found different measurements depending on where I measured (of course). So where is the correct point of measurement?
Thank you
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 15, 2006
  • Oct 15, 2006
Simple method: put a zip bag with kitty litter on top of the intake manifold. Leave enough extra space so that the kitty litter can spread out inside the bag as it compresses. Push the kitty litter inside the bag so that it makes a 3” pile. GENTLY close the hood so that it latches shut. Open the hood, being careful not to disturb the bag, and measure the height of the pile of kitty litter to determine the clearance.
Alternate method: use a 3” wad of modeling clay or Play-Dough on top of the manifold. Put a piece of heavy paper or plastic sheet over the top of the clay. This prevents it from sticking to the underside of the hold. You may want to do the same thing to the top of the intake manifold to keep the clay from sticking to it. GENTLY close the hood so that it latches shut. Open the hood, being careful not to disturb the bag, and measure the height of the pile of clay or Play-Dough to determine the clearance.
soontobefastfox
275
Troy, Michigan
Oct 15, 2006
  • Oct 15, 2006
I should have been more clear. I know I need a cowl because my hood won't close due to my intake spacer.
R
r.barn5.0
107
  • Oct 15, 2006
Its usually the front of the intake that will hit.
with hood up, take long sturdy straight edge and run it
from top of front qrt panel on each side just in front of the intake.
now see how far your intake goes above that line.
you could probably also run a tight string across.
problem with lifted cowl hoods is the max lift is in the back
and you need the lift about mid hood.
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
J
88 Foxbody 5.0 Driveshaft Issue! Need Help
  • James Hood
  • May 1, 2025
Fox 5.0 Mustang Tech May 1, 2025
AeroCoupe
LX Rear Trunk Lid Emblem Install Measurements
  • Habu135
  • Oct 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Habu135
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
