Mechanical or Electronic Distributor???
FordRacing302
5 Year Member
Oct 1, 2005
384
42
59
Cleveland, TN
I have an 83 GLX that the previous owner dropped a carbed 5.0 inplace of the factory EFI V6...The problem is the car doesnt run, its gets gas but no spark, And its a huge mess of wires under the hood mainly becasue of all the old EFI system. So i wanna take the cheap and easy way out and buy a regular mechanical vacuum advanced distributor and put that in place of the electronic one, BUT my dad wants me to mess with all the electronics and figure out the wiring nightmare to get it runnin......I like the my idea a helluva lot better, but my dad wont let me buy the new distributor until i get a second opinion....So what do yall think i should do?
If it's carbed you HAVE to run an old-style mechanical distributor if you want to have any ignition advance. The EFI dizzy has advance that is electronically supplied by the efi/electronic ignition; you can't use it with a carb for street cars that need advance.
If you're sticking with a carb you can/should do away with all the non-related efi wiring. Tell your dad this is from another 'old' dad.
Michael Yount said:
That's a nice piece -- I got the impression he was trying to keep it to a bit tighter budget though....
Do you know if the gear material is compatible with the roller cams in the HO's?
Excellent question - the info on their site does not give any clues. I would suspect that the standard product would be for non roller cams. Contact them and I'm sure they have an answer or fix.
FWIW IIRC (LOL - enough acronyms?), a roller-motor uses a steel gear (JR and Yount both know that, but someone else might not. Plus if my memory is faulty, someone can correct me).
Good luck with the project.
Thanks for all the advice guys...Im on a really tight budget, and I paid $300 for the car so I dont wanna spend big bucks. I just wanna find the cheapest, easiest way to get the car running...Autozone has a core charge of the distributor I need for $39.99 and it has a lifetime warranty, So I think im gonna go with that
Thanks for all the help
It's easy to recurve that distributor and the performance will improve significantly. I'd set it up for about 14-16 degrees initial timing, and about 34-36 degrees total all in by about 3000 rpm. The carbed motor will love that. If it has vacuum advance, after the recurve described above, you can do away with the vacuum advance altogether.
