mechanical vs electrical gauges
  • Thread starter Thread starter Lang
  • Start date Start date Aug 28, 2006
L
Lang
17
Lorain, Oh
Aug 28, 2006
  • Aug 28, 2006
I've been thinking of upgrading my guages; oil pressure, water temp mainly. what is the difference btwn mech an elec? is one better than the other or is one easier to install? thanks
D
dec322
401
Bham AL
Aug 28, 2006
  • Aug 28, 2006
I chose to take the electrical route. The reason being, I didn't want to run tubing inside the car carrying oil or antifreeze. I wondered the same and posted the question on here a couple of months ago. Here is the link with some pics. Enjoy and I hope this helps.
RYC CUKR
1,437
Orlando
Aug 28, 2006
  • Aug 28, 2006
Personally I like mechanicals. But its just a personal preference. The autometer electricals are great gauges. When I routed my gauge feed lines into the car I chose to use the stainless braided hose with AN fittings on each end. I used that for my oil and nitrous gauges. The water temp gauge has a capillary tube built in so you don't have a coolant mixture in a hose.
Either will work fine. Electricals are nice where space is at a premium such as when mounting gauges on the a pillar.
D
dec322
401
Bham AL
Aug 28, 2006
  • Aug 28, 2006
This is the reason I went with electrical. I didn't want to route the lines into the pillar pod. Now if I was rich and money wasn't an issue, I would buy the florida gauge thingy and replace the speedo, tach, fuel, WT, OP, and Volt with all mechanical full sweep gauges.....
But I'm not.
HISSIN50
34
129
Aug 28, 2006
  • Aug 28, 2006
I like electric OP in pillar pods and mech temp gauges (period).
Good luck.
T
TheUser
1,859
Springfield, MO
Aug 28, 2006
  • Aug 28, 2006
w/ mech water temp, you can see what the temp is literally all of the time - car running or not...for some reason, I think that's cool
sketman
1,379
12
58
Palm Bay, FL
Aug 28, 2006
  • Aug 28, 2006
Mechanical oil pressure and water temp here on the A-pillar. No regrets. Slightly more time-consuming to install, but I spend way too much time on the car anyways, so that was hardly a concern of mine.
And as an FYI, coolant doesn't enter the inside of the car with the mechanical water temp gauge.
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
