I have a Stinger Pimpxs ecu. I was looking through some of the available tables and found injector timing. According to the help function, the listed values are degrees btdc. The values start off at 550 in the lower rpms and drop to 400 at higher rpms. This seems backwards....no? Looks like you would need the injectors to fire sooner at higher rpms. Can someone explain?
