• Community Forums
  • Regional Forums and Event Information
Melbourne area stangs
  • Thread starter Thread starter BlackMagic
  • Start date Start date Nov 1, 2001
  • 124
  • 125
  • 126
  • 127
  • 128
  • 431
First Prev 126 of 431 Next Last
baglock1
The Bartender
6,612
Space Coast, FL
May 1, 2002
#2,501
  • May 1, 2002
  • #2,501
Originally posted by Jims5543
you misunderstand my statement/question. At what speed do you aerodynamically need the downforce from a wing??
My RX-7 is very stable all the way to 150 mph - I havent been faster than that yet.
I would consider a front air dam first keep the air from under the car.
My $0.02
Really though I wonder at what speed you need addtional downforce.
It depends on a lot of things. If the car is stable at high speeds, there's no need to add the weight and wind resistance of a wing. If, however, your car is like mine and is all over the road at 130, things need to be done. Improving under chassis aerodynamics is typically the best way (lowering it and adding an air dam, like you said). Special hoods, like Griggs heat extractor hood also help by pulling air from under the car (resulting in low pressure) and allowing it to flow over the car (resulting in relatively higher pressure).
High wind velocity actually creates lower pressure (the same reason a plane flies) so when high speeds are reached, low pressure above the car actually sucks it up, resulting in less traction. Definately a bad thing cooking into a corner at 120. If the low pressure below the car is unable to compensate for the low (but relatively high) pressure over the car. Other methods must be employed. Hence, a wing to help provide additional downforce.
baglock1
The Bartender
6,612
Space Coast, FL
May 1, 2002
#2,502
  • May 1, 2002
  • #2,502
Originally posted by White93'LX2.3
ok baglock, i went and played on the highway tonight, and it was fun to say the least! ok now to the important part, i dont know exactly what speed i was going(speedo only goes to 85 and it was well past that), but my car topped at 5000 rpms and kinda bounced back alittle and thats when i let off! if i had to guess speeds, i would say between 90 and 95, i dont know exactly, but best guess maybe like 92 or 93! i hope that info helps, cus i want to go talk to TJ tomorrow about doing the gears!
Accurate results would be nice. Instead of maxing the speedo, get to 65 (on the mark) and tell me what the tach says. Or get to 3500 or 4000 RPM's and tell me what the speed is. I need accuracy to get accurate results. Also, I still need the tire size.
BlackMagic
2,808
Central Florida
May 1, 2002
#2,503
  • May 1, 2002
  • #2,503
ok ill try again tomorrow, the only acurate speed and rpm i know is in first so that wont help! and the tire size is 205/65/15.
baglock1
The Bartender
6,612
Space Coast, FL
May 2, 2002
#2,504
  • May 2, 2002
  • #2,504
According to my calculations, you have 4.11's if you were doing 92. If you really do have 3.73's, then you were doing 101. It's tough to say because of the automatic. You were in 3rd, right? Not 4th, or overdrive? If so, I'd say you have 4.11's in the @ss end. There is an easy way to check for sure and involves jacking a wheel off the ground.
As far as the 4.56's, not knowing what the final drive in your auto is, I can only compare it to that of a 5spd OD (not perfect, but close I'm sure). In that case, at about 80, you'd be turning a little over 3.5K.
BlackMagic
2,808
Central Florida
May 2, 2002
#2,505
  • May 2, 2002
  • #2,505
i had it in regular drive. it shifted from first at redline, from second at redline, and it didnt shift again! i got it up to 5000 rpm and it would go anyfurther, and then just went back to like 4800 or 4700! i was surprised at the rpm's i was getting! i didnt even think my littel 2.3 had it in her!
baglock1
The Bartender
6,612
Space Coast, FL
May 2, 2002
#2,506
  • May 2, 2002
  • #2,506
I just realized that I blew past 1500 and didn't even notice! Oops, sorry guys. I would've put it here if I'd known.
erichmess_
Member 4 Life
6,836
10
79
Miami
May 2, 2002
#2,507
  • May 2, 2002
  • #2,507
Congrats Baglock 1! Now just sit back and wait for that CT to come in. "Man with Big Wing" J/K
erichmess_
Member 4 Life
6,836
10
79
Miami
May 2, 2002
#2,508
  • May 2, 2002
  • #2,508
Nope. I haven't been over to the mainland since last week.
Okay, it did look a lot like your car, though. Glad I didn't wave, then.
erichmess_
Member 4 Life
6,836
10
79
Miami
May 2, 2002
#2,509
  • May 2, 2002
  • #2,509
You're assuming we don't have the capability to "see" through into your garage, and beyond...
Say, can I give you the address' of some hot chicks...I mean, um, potential terrorists, and have you take some "and beyond..." pics.
BlackMagic
2,808
Central Florida
May 2, 2002
#2,510
  • May 2, 2002
  • #2,510
ya damn horn dog!
BlackMagic
2,808
Central Florida
May 2, 2002
#2,511
  • May 2, 2002
  • #2,511
well finally got under the car, and i have 3.73's so that ends the quest to find out what i have! now i just need to decide what i really want to do with the car! i hate making decisions!
NotQuik
5,158
29
88
Central Florida
May 2, 2002
#2,512
  • May 2, 2002
  • #2,512
The 5 speed 92-93 2.3's have 3.45's and the auto have 3.73's from the factory. Not sure on the older ones.
erichmess_
Member 4 Life
6,836
10
79
Miami
May 2, 2002
#2,513
  • May 2, 2002
  • #2,513
ya damn horn dog!
Hey...don't worry, I'll share. I'll pay baglock some good money for them, too.
BlackMagic
2,808
Central Florida
May 2, 2002
#2,514
  • May 2, 2002
  • #2,514
as long as you share!
erichmess_
Member 4 Life
6,836
10
79
Miami
May 2, 2002
#2,515
  • May 2, 2002
  • #2,515
I'll make copies for everyone. You will all me.
U
Untouchable
364
Florida
May 2, 2002
#2,516
  • May 2, 2002
  • #2,516
except me
BlackMagic
2,808
Central Florida
May 2, 2002
#2,517
  • May 2, 2002
  • #2,517
Originally posted by Untouchable
except me
oh come on, i thought that you went both ways!
erichmess_
Member 4 Life
6,836
10
79
Miami
May 2, 2002
#2,518
  • May 2, 2002
  • #2,518
LMAO!
U
Untouchable
364
Florida
May 2, 2002
#2,519
  • May 2, 2002
  • #2,519
lets not get into that ... oh i saw a vw bug today, it was bright green with turbo stickers all over it, of course it was lowerd w/ the coffee can exaust and had a body kit, but that's not what caught my eye, as i was leaving an old fat lady walks up to the car and gets in it, i thought it was kinda funny ... but then again i'm easily amuzed ...
BlackMagic
2,808
Central Florida
May 2, 2002
#2,520
  • May 2, 2002
  • #2,520
thats some funny *****
  • 124
  • 125
  • 126
  • 127
  • 128
  • 431
K
Introduction
  • kleach
  • Feb 10, 2026
  • The Welcome Wagon
The Welcome Wagon Feb 10, 2026
gkomo
F
Help with air bag code 2293
  • Felwinters
  • Apr 23, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Apr 23, 2026
Felwinters
F
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
  • Community Forums
