Messed up power steering. Help!
Your power steering pump is most likely failing. It isn't a common problem on those cars, but it does happen every now & then. Take a look at the power steering fluid. Is it a dark red or brown, or even close to black in color? Smell it also - does it smell burnt? If either of those fluid concerns are present your pump is the the problem.
Yea the fluid is black. Thanks for the help I had a feeling it was the pump.
