Methanol conversion ?
  • Thread starter Thread starter 98V6
  • Start date Start date Sep 6, 2005
1 of 2 Next Last
9
98V6
43
Baltimore, MD
Sep 6, 2005
  • Sep 6, 2005
Does anybody know anything about converting to use methanol ?
M
mr.b
214
  • Sep 6, 2005
what u want to know, i run methanol on my dragster.
9
98V6
43
Baltimore, MD
Sep 6, 2005
  • Sep 6, 2005
What would have to be changed to run methanol in a 5.0 or 4.6 ?
blwngt
12
  • Sep 6, 2005
are we talkin methonal injection.....
9
98V6
43
Baltimore, MD
Sep 6, 2005
  • Sep 6, 2005
no not injection, running off methanol, like dragsters do. I am not seriously considering this, just curious.
T
tjm73
2,418
Rush, NY
Sep 6, 2005
  • Sep 6, 2005
You need high compression in the area of like 13 or 14:1 and you will need around 4 times as much fuel if memory serves.
Almost everything else is already ok to run methonal. Most rubber in today's cars fuel systems is high quality enough to survive.
The engine block and head bolts aren't up to the task. It generates a lot higher cylinder pressures and headgasket life will be severly reduced.
T
tjm73
2,418
Rush, NY
Sep 6, 2005
  • Sep 6, 2005
For my own knowledge can you share the basic engien parameters for a MEth running race engine?
C/R?
A/F Ratio?
Any other special considerations?
9
98V6
43
Baltimore, MD
Sep 6, 2005
  • Sep 6, 2005
C/R?
A/F Ratio?
yeah thats what I am looking for, I was told that the Meth would eat valve seals and manifold gaskets any truth to that.
vristang
4,933
101
124
Seattle
Sep 6, 2005
  • Sep 6, 2005
subscribing and bumpingSorry I can't contribute, but I am curious.
txstang84
1,639
42
69
Tuscola, tx
Sep 6, 2005
#10
  • Sep 6, 2005
  • #10
doesn't the meth have to run about 9:1 AFR?
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Sep 6, 2005
#11
  • Sep 6, 2005
  • #11
Methonal can run the same compression ratio's as gas can.Its just better to use higher compression to take advantage of the capibilities of methonal.
Fuel consumption is roughly double that of gas.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Sep 6, 2005
#12
  • Sep 6, 2005
  • #12
Also,methonal is corrosive to bare aluminum.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Sep 6, 2005
#13
  • Sep 6, 2005
  • #13
wonder what would happen if you took a stock 5.0 and ran nitro methane in it?
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Sep 6, 2005
#14
  • Sep 6, 2005
  • #14
...............................BOOM!!!
vristang
4,933
101
124
Seattle
Sep 6, 2005
#15
  • Sep 6, 2005
  • #15
A brief summary of what I found in the SAE Bosch Automotive Handbook (5th Edition).
Alternative fuels methanol and ethanol are being explored. Ethanol is only being used extensively in Brazil due to availability. Methanol is being mixed with gasoline, up to 85% (M85). Methanol generates lower NOx and CO2. Alcohols are more demanding on engines and fuel delivery components. MOisture , acids and gums contained in the fuel pose a hazard to metals, plastics, and rubber. Methanols higher anti-knock characteristics allow higher compression ratios for engines that run exclusively on methanol (not Flexible fuel cars). Methanol has a lower calorific value than gasoline which requires special injectors. Also the higher rates of consumption require larger fuel tanks. O2 sensors are mentioned but it is not clear if wide bands, or some other special O2 sensor is required. "Special" lubricants are needed for long term stability when exposed to the fuel and its combustion by products. Flex fuel cars have a sensor that detects the amount of methanol in the fuel so that the computer can make the necessary changes.
These are some of the design issues that concern the major auto makers
M
mr.b
214
#16
  • Sep 7, 2005
  • #16
it takes about twice the methanol versus gas. I have ran methanol on a 9:1 compression motor before. The only problem was getting it to start on cold days. This is fixed by starting it on gasoline. It is pretty corrosive and attracts moisture. Had to change the oil about every 20-25 runs. It has a high knock resistance and the biggest advantages of it are reached by running high compression. It costs about 2.00 a gallon (but i was told this past weekend it would be going up about .40 to .50 a gallon). It is fairly corrosive, i have taken apart a bg280 pump i ran with all year and the vanes and rotor had definetly had some etching and metal erroded from them. running it through fuel injectors probably wouldn't last too long, would start to corrode and eat them up. It also isn't to friendly to rubber or raw aluminum (not anodized).
9
98V6
43
Baltimore, MD
Sep 7, 2005
#17
  • Sep 7, 2005
  • #17
So the main advantage is, it does not knock as wasy, so you can run alot more boost, timing, compression ect.
Down side, it eats injectors, pumps and anything metal.
Right ?
9
98V6
43
Baltimore, MD
Sep 7, 2005
#18
  • Sep 7, 2005
  • #18
So if I lived in florida where I would NOT have to worry about cold starts, and even though it burns twice as fast as gas if it was half the price of gas could you run it all the time in a daily driver ?
vristang
4,933
101
124
Seattle
Sep 7, 2005
#19
  • Sep 7, 2005
  • #19
Running on M85 would be a better solution at this time. M85 is used by the military, and other industrial areas, so it can be found in most parts of the country. Cold start is not a concern and you get the benefit of running higher compression.
just myopinion.
M
mr.b
214
#20
  • Sep 7, 2005
  • #20
running pure methanol on an everyday driver is not really going to work that great. you would have to completely redo your fuel system and get injectors that would be up to the task. (you need alot more fuel flow) plus you would need to flush the system with gasoline very often to keep the injectors from corroding up(at least this is what is said on MSD's website since they carry alcohol compatable injectors). it sounds easier said than done. the m85 is the closest thing you would get to doing what you would like to do since it is a blend of both.
in the long run it is going to cause you alot more headache and price for what it is worth. at around 2.00-2.50 a gallon and using 2-2.5 times as much than gasoline, it will cost more to run it.
1 of 2 Next Last
Engine Fan temp sensor location.
  • 7-UP BILL
  • Apr 3, 2026
Fox 5.0 Mustang Tech Apr 7, 2026
KRUISR
M
1985 v6 to v8 carb swap
  • mgriffin_2222
  • Mar 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 9, 2026
mgriffin_2222
M
K
Engine rebuild in connecticut
  • Kngtmare
  • Aug 30, 2026
Potomus Pete
L
Door pull panels, convertible versus coupe
  • lenzgt
  • Jun 25, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 25, 2026
lenzgt
L
For Sale Hogans Racing Intake manifold for SBF
  • Bullitt347
  • Jun 7, 2025
  • Engine and Power Adder
Engine and Power Adder Oct 8, 2026
Qtrhrse23
