  • SN95 4.6L Mustang Tech
methanol injection on n/a
  • Thread starter Thread starter austin_hubbell
  • Start date Start date Feb 11, 2007
A
austin_hubbell
California
Feb 11, 2007
  • Feb 11, 2007
I have seen alot of sc cars benefit from a snow performance methanol injection kit, my car is not sc but i was wondering if anyone is running it on a na car and seeing any gains. They have a kit that is driven off of mass air voltage and not boost value so it would work on my car just wanted to see people's thoughts and if anyone is running one.
thanks
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Feb 12, 2007
  • Feb 12, 2007
not really.
the advantage of meth/alch/h2o injection is to cool down the air charge, and depending on whats injected, help increase the octane rating of the overall fuel charge, which will aide against knock/predetonation. this in turns means you can run more timing and lean out the mix, or add more boost.
i dont really see its advantages n/a unless youre fully fledged n/a with high compression, awesome cams and whatnot, and at that point its probably a track only vehicle, so you might as well be looking into running straight methanol anyways.
sgarlic
3,085
Feb 12, 2007
  • Feb 12, 2007
thomas91169 said:
not really.
Now wait a second here. You are right in that the intent is to cool down the incoming air.. definately.
But the octane rating is of the gasoline. Cooling down the air before it hits the intake does exactly that, cools the air down. Recall, the octane rating is in a nutshell the ability of the gasoline to resist spontaneously combusting. Air doesn't spontaneously combust, so really cold (or really hot) with gas doesn't change the properties of the orignal gasoline. But as you said, it can help against detonation.
Now, as far as doing this N/A, I would think very very minimal gains from trying this. Everyone knows cooler air = denser.. so probably would result in the gains you'd see driving in a really cold day with that really cold air all the time.
A
austin_hubbell
California
Feb 12, 2007
  • Feb 12, 2007
I figured gains would be minimal but i was curious about anyone running one. well thanks for the replies
T
thomas91169
Aug 19, 2005
Modesto, CA
Feb 12, 2007
  • Feb 12, 2007
yes, but depending on what you inject, be it alcohol, methanol, etc., it will raise the overall fuel charge octane rating (standard fuel used + whatever is injected = overall fuel charge). so if you run 91 octane and then whatever you are injecting will help raise the overall octane rating.
04YELLOWGT
1,135
Indiana
Feb 12, 2007
  • Feb 12, 2007
It actualy does raise the oct of gas, Alternative Auto Performance is big into this and they even say running 93 with meth it increases it to 110 oct. Check it out.
http://www.alternativeauto.com/waterbox/waterbox_main.html
I looked it to this for my car but I saw so many guys losing there engines I decided to just do an IC.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
