MGW Shifter Install
03BlackGtmach
Hi guys I just finished install my MGW shifter in my car, awsome shorter throws, my question is that do you install the small shifter boot that was on the base of the stock shifter or do you leave it off and just use the iner dust boot that uses the four mounting bolts??
Thanks.
Here is my install how to:
http://forums.stangnet.com/showthread.php?t=528042
The boot snugs all the way to the bottom.
I did it first without the lower boot (stock) and because I have a slight noise there where I didn't with the stock slop, I decided to go back and put it on. No change. It has not affected me either way. If you didn't use it, don't worry about it.
JS
