Hey guys, finally got her installed. Although I was not able to take as many pictures as I wanted to for a write up I still snapped a few. My Saturday was way more busy than I expected it to be. I work 3rd's so I wasn't off until 7am Sat. morning. So I woke up at around 2pm and went to workin' on the vehicles. I went over to my moms and changed the oil and filter in her Taurus and did the fuel filter, air filter and oil/filter on my step dads truck. Then I did the shifter on mine all the while knowing I had to be somewhere at 6pm. I ended up getting everthing done without cutting corners (Besides the picture taking). So here goes:
Step one, prepare for carnage:
Step two, remove top part of center console that is held by two (2) phillips screws at the back end under the lid on the storage space at the rear of the center console:
Should look somewhat like this near the shifter:
Step 3, uh.... we don't have a step three yet.... (Obscure South Park reference anybody?) :
Step whatever because I'm missing a bunch of pictures, long and short of it is there are two (2) 10mm nuts on the end of two studs that hold the back of the factory shifter on, after you remove those you can remove the the linkage at the bottom of the shifter (one (1) 8 mm bolt IIRC). Swing the linkage toward the drivers side. Then you can disconnect the part of the connector hard mounted by the long black rod connected to the transmission case.
You take the shifter out through the top. You could take it out through the bottom if you removed the driveshaft but I was using two jack stands, so I opted not to.
Its out! wOOt :
Its out! wOOt :
