Mil Eliminator Help
  • Thread starter Thread starter 90lxwhite
  • Start date Start date May 23, 2012
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
May 23, 2012
  • May 23, 2012
the mil elminators help I'm needing isn't on a mustang but my wifes expedition, I went to their forum but got no replies. Awhile back I had to replace the cat on my wifes 07 expedition w the 5.4 litre and I put a universal cat on and the CEL is still on. Are MIL eliminators universal, do you think the ones that american muscle are selling for the 96-04 or whatever mustang would work on her car as well?? Thanks
mike
Bojingles
Well-Known Member
May 10, 2012
329
35
63
Barksdale AFB, LA
May 23, 2012
  • May 23, 2012
Wait... Did you put on a new cat and leave the O2 Sensors where they are or did you install a new cat and remove the O2 sensors?
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
May 23, 2012
  • May 23, 2012
new cat and new front O2's in the same location as oem, the backs are the old ones. For some reason the universal cat didn't work. I had the work done where my parents live which is about 2 and a half hours away and about midway though the trip the check engine light came back on. Computer was reset of course during the cat install.
Bojingles
Well-Known Member
May 10, 2012
329
35
63
Barksdale AFB, LA
May 24, 2012
  • May 24, 2012
Are you sure the MIL light is coming on for a O2 sensor code and not something else? What's the code you're getting?
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
May 24, 2012
  • May 24, 2012
not sure the code in number and alph form, but took it to two parts stores had em do OBDII scan and they sat it was the cat and the muffler shop said it was also.
Bojingles
Well-Known Member
May 10, 2012
329
35
63
Barksdale AFB, LA
May 25, 2012
  • May 25, 2012
jpplaw
185
May 25, 2012
  • May 25, 2012
P0420 & P0430 are the typical codes for cat efficiency. Happens all the time when replacing stock cats with hi-flow cats. Can be a bi**h to stop from happening. Double anti-foulers aren't working on mine and I can't turn the rear O2's off because of state inspection
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
May 29, 2012
  • May 29, 2012
I tried the double anti fouler trick on friday but haven't driven it enough to know if the ligh is gonna stay off. Im crossing my fingers but not betting the farm on it.
bigb427
128
Las Vegas, NV
May 29, 2012
  • May 29, 2012
I have seen this problem a lot when it comes to aftermarket convertors - they are junk.
Instead of dumping more money on the problem, you should return to the shop that installed the convertors and have them install another set under their warranty. You may get lucky and get a good set. If after having another convertor/convertors installed and the problem still exists, demand your money back. After you get your money back go to the Ford dealer and have a Ford convertor put on it.
Bad Boss 302
170
#10
  • May 30, 2012
  • #10
The converters at the Ford dealer often run over $1000 each. Of course they work.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
May 31, 2012
#11
  • May 31, 2012
  • #11
Yeah next time I head up that way, (bout 2 and and half hours) from my house I'll swing by that shop. I've been running w the cel on for 'bout 2 months now and it's not running any bad or using anymore fuel or anything like that, the light is just annoying but I'm bout used to it by now. The light came on but half way home when i got the cat put on. More than likely I'll prob just ride w the light awhile. When I got it inspected I just reset the ecu and it passed.
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Engine Backfiring and Shaking Pony
  • Krazykyle44
  • Mar 15, 2021
2K
Fox 5.0 Mustang Tech Mar 17, 2021
General karthief
A
Should I bother (re)investing into my 96 Mustang GT or should I sell it?
  • Adrift98
  • Jun 15, 2018
2K
1996 - 2004 SN95 Mustang -General/Talk- Jun 17, 2018
Neuron
Progress Thread 1995 3.8L Vert (2002 3.8L Dual Port Engine)
  • kiddiccarus
  • Dec 30, 2018
12K
1996 - 2004 SN95 Mustang -General/Talk- Feb 25, 2023
kiddiccarus
