mil eliminator problem!
yz250
40
hey i got some mil eliminators for my 01 snake, and the right passengers side won't fit. the alignment tabs on the mil don't line up to the factory hookup. anyone else had this problem? i've heard you can just cut the alignment tabs off. also, how would you prevent the mil from from hanging on the exhaust pipe. and its been over 300 miles since my cats have come off, and my mil still hasnt gone off. if it does, will that screw up my air/fuel ratio?? help help help. thanks.
You will need to cut the tab off so it will plug in. Use zip ties (cable ties) to keep the wires up off the pipes. The light will not cause a change in a/f ratio.
