Mil Eliminators
  • Thread starter Thread starter 90lxwhite
  • Start date Start date May 23, 2012
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
May 23, 2012
  • May 23, 2012
Do you guys think that the mil eliminators made for the 96-04 mustang would work on an 07 expedition with the 5.4 liter by chance? It's the wifes, and recently I got a code for bad cats so I changed them with universals and now I still have the code. I don't want to spend the $1500 or whatever it was for an oem catalytic converter. Thanks if anyone knows anything. I tried getting some info on the ford trucks forum but no one really responded. So I thought I'd try old faithful
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
May 23, 2012
  • May 23, 2012
why not just get a hand held tuner for it and have the tuner turn the back 02's off?
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
May 23, 2012
  • May 23, 2012
because I'm guessing there is about a $250 difference.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
May 23, 2012
  • May 23, 2012
Yeah slick just "googled" a tuner and superchips is wanting $429 for theirs vs the $80 mil eliminatior. I hear a fella can make one from radioshak parts on the fairly cheap but im not that confident in my wiring skills so I'd rather have a plug and play. But yeah why not spend $430 to turn off rear o2's... I'd rather ride w the light on
2000xp8
SN Certified Technician
Aug 8, 2003
8,068
1,655
194
NJ
May 23, 2012
  • May 23, 2012
I'd try and find out what the real problem is first before investing in parts to circumvent the issue.
If the original set of cats on an 07 where bad, i'd say there is an issue that caused that.
o2 sensors usually don't care what brand cat you put in either.
I have a feeling there is an underlying issue causing your problem.
stykthyn
5,232
2,652
223
gainesville
May 23, 2012
  • May 23, 2012
Were they fouled from whatever killed your cats? Cats don't just fail. Typically with mod motors I see leaking head gaskets at the number 4 cylinder spewing moisture into the exhaust any toasting the cats.
TOOLOW91
20+ Year Stangneter
8,761
234
S.I.NY
May 24, 2012
  • May 24, 2012
Spark plug non foulers , ran 2 on each side on my 00gt with no cats and never had a cel
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
May 29, 2012
  • May 29, 2012
PS: I think some fuel injector cleaner is what killed the cat
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
J
  • JRC99
  • Apr 19, 2025
JRC99
J
