- Feb 11, 2007
- 228
- 0
- 0
Replaced my valve covers and noticed oil color on rockers similar to that of the color of coffee after sugar has been mixed in about this color
I know, classic head gasket symptom but mind you I have had the car parked since Dec. swapping to carb and the car has seen no hot cycles, just brief 30 second occasional idles while I adjusted the carb. I also found white vaseline type consistancy goo on the old valve covers (which has since vanished off them in the floor of my garage). Valve cover breathers appeared to have water droplets on them
frantically I performed an oil change yet every bit of what drained out was normal pure dark oil
could this be some type of condensation mix after having the top end off and short 30 sec runs with no hot cycles or am I likely looking at bigger probs?
Radiator coolant level is holding at full and hasnt dropped
I ran it to hot a few minutes ago and engine temp holding at normal after a 30 minute drive around the block and exhaust smells normal with no smoke
thanks
thanks
