  • SN95 4.6L Mustang Tech
Misfire help!
  • Thread starter Thread starter mhissticobra
  • Start date Start date Aug 27, 2005
M
mhissticobra
61
  • Aug 27, 2005
Here's the situation: The car was running fine, I then installed an Autometer oil pressure and water temp gauges. After hoopking them up, I start the car and I automatically get a CEL. I went and had the code scanned and it was p0300 random/multiple misfire. I go home and let the car idle, you can hear it missing. I know that gauges are hooked up ok becaue they read what they should and anyways they wouldn't make my car misfire. I checked all connections related to the ignition system. I have done research and have installed new coil packs, plugs, new FRPP wires, tightened the crank bolt to 130lbs (was already tight), put new gas and dry gas in and it still misfires!!! WTF!! I am out of ideas, my last hope is to call my dyno tuner and see what they say. Anything I didn't check or should check. HELP!!
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 27, 2005
  • Aug 27, 2005
Maybe it is as simple as resetting the PCM?
What year is it?
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
LT headers/ CEL misfire
  • Starxk
  • Jul 28, 2025
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jul 28, 2025
