Hey All,
Well the car has been driven a tiny bit but I've been holding back getting out and enjoying it because I have a bad misfire.
Cylinder #2 is not firing at all. At idle if I pull the plug wire off the plug there is no change in the tone of the engine. I've pulled the plug and it is dark (they are all new plugs) and wet. I installed a used plug that I had lying around, thinking that perhaps it was just a bumb plug... and sure enough it began to run on all 8. I took it for a quick run, came back, washed the car, went to take it for another run and I was back on 7 cylinders again. No swapping plugs doesn't do anything...I have not been able to get it to run on 8 since.
Last night I installed another new plug, wires, cap, and rotor with no change. This is a stock 1988 5.0L with approx. 100k miles on it.
I did have the injectors out of the intake manifold for about a year and they were stored in a ziplock bag. Any chance that I have a stuck injector that is just dumping fuel into the cylinder...is that common at all? I guess I should also invest in a compression gauge and see where I'm at there. I really hope it's not a stuck valve or rings.
I do not see any odd smoke coming out of the tailpipe...although there is some black in the condensation coming out of the tailpipe.
Any words of wisdom?
5.0L Miata
5.0L Miata
